kartable
video output with VGA-C connector
Fri Jul 17, 2020 12:03 pm
Hi to all,
I have a PC screen which I intend to use with my new Raspberry Pi 3 B+ and I exeprience some flickering on this "old" screen, whereas it's perfect on my TV screen with HDMI.
Thanks to this thread viewtopic.php?f=91&t=83372&p=589714#p635072 I had been warned that a VGA output could not work with the Pi's HDMI. I then purchased a cable with a VGA-C connector, also called DVI connector. And at first glance, it works.
But as I say, the video output is flickering sometimes with a black screen for as long as a second. Can this be solved?
hippy
Re: video output with VGA-C connector
Fri Jul 17, 2020 1:30 pm
Maybe it's an issue with the monitor ?
I, and I'd guess many people, use monitors with DVI inputs so use HDMI-to-DVI adapters and I've not experienced such problems, nor recall seeing reports of the problem from others.
Fri Jul 17, 2020 2:45 pm
I don't know about DVI-C (I've never heard of one of those), but a DVI-D cable should work fine with most monitors with DVI connectors.
Some older monitors (PCs and cables) use DVI-A (analogue), which is basically just VGA on a DVI plug. It is not compatible with DVI-D (Digital).
There is also a DVI-I, which has both types of DVI connections.
Unreadable squiggle
njh
Fri Jul 17, 2020 3:06 pm
It sounds like the OP may be using a HDMI-to-VGA converter rather than just a DVI cable?
What kind of adaptor is it exactly?
Some of them can be fussy about video modes (try changing the screen resolution in "preferences") or power supplies.
kartable
Sat Jul 18, 2020 7:24 am
Changing the video modes could have been a right guess. I've tried most of them, also with different Hz settings, but no way.
rpdom wrote:I don't know about DVI-C (I've never heard of one of those), but a DVI-D cable should work fine with most monitors with DVI connectors.
Re this https://components101.com/connectors/dvi-connector, I have a DVI-D input on my device.
And my cable is this one https://fr.aliexpress.com/item/32830411 ... 6c37lJar6V
hippy wrote:Maybe it's an issue with the monitor ?
This monitor works quite well with my PC running Windows 10.
For some reason, a flash appears on the top right corner which means a high consumption, as far as I understand. So I modified the config.txt file with an additional line "max_usb_current=1", but this doesn't help.
EDIT : I realise that I can switch the input from the screen itself from VGI digital to analog, should I try that?
B.Goode
Sat Jul 18, 2020 9:54 am
D0 you mean the Yellow 'lightning flash' show here - https://www.raspberrypi.org/documentati ... g-icons.md
If so, your problem is due to an inadequate power supply for the RPi board itself, probably worsened by the current drawn by the video interface.
kartable
Sat Jul 18, 2020 11:58 am
That's it
I am using a 5V 2.5Amps power supply for my Raspberry. Is it possible that my "old" PC screen device draws much current from the Pi when both have their separate power supply?
The flash icon never shows up on my TV screen.
Sat Jul 18, 2020 12:23 pm
The 3B+ needs three amps. The new (at the time) PMIC on that one has always been a bit power hungry and sets the lower power warning early.
trejan
Sat Jul 18, 2020 12:28 pm
max_usb_current only does something on the Pi 2 where it changed the USB port current limiter from 600mA to 1.2A. It does nothing for every other Pi. It doesn't help with undervoltage issues anyway.
Sat Jul 18, 2020 12:59 pm
Wasn't it the Pi 1B+ that had that? I thought the Pi 2 had it set to high anyway. In fact I think later "firmware" set that option as standard on all Pi that support the option.
Unreadable squiggle
kartable
Sat Jul 18, 2020 1:08 pm
Well I purchased the official power supply that's rated 2.5 Amps for the 3B+ so I don't understand at all.
trejan
Sat Jul 18, 2020 1:13 pm
Looks like it was for the 1B+ and 2B. The 3B onwards had no choice and it was 1.2A always.
hippy
Sat Jul 18, 2020 1:23 pm
It's possible, but the 2.5A recommended for the 3B+ includes some 1.2A spare capacity for powering USB devices.
You seem to be using a standard passive HDNI-to-DVI cable so it is hard to see how a monitor would draw so much current through the HDMI port that it puts the Pi into an under-voltage situation -- which is presumably what's causing the monitor to blank its display. The Pi then recovers, the monitor re-displays, rather than rebooting.
Drawing just a little current could however tip the Pi over the edge if current were being drawn elsewhere. What else do you have connected via USB or to the 40-way connector ?
It might be worth trying with keyboard and mouse unplugged, nothing attached via USB, seeing if that improves things.
hippy
Sat Jul 18, 2020 1:28 pm
2.5A recommended according to the official documentation - https://www.raspberrypi.org/documentati ... /README.md
hippy
Sat Jul 18, 2020 1:58 pm
One thing I have noticed with my collection of TV's is they do not seem to draw power from pin 18 of the Pi's HDMI port.
The power for their internal Eeprom appears to be provided only internally, and often only when turned on. When turned on the EDID information can be read. Also for a period after putting the TV in standby. But not after being in standby for some time, when the Eeprom power rail reservoir will have discharged. Took me some time to figure out what was going on there.
Monitors on the other hand do seem to draw current from pin 18, or power the Eeprom internally when connected to mains, even in standby or sleep modes, or showing the other input.
It could therefore point to a pin 18 issue, the monitor drawing too much current perhaps.
I had noticed, when using Pi's on sub-optimal, under-rated PSU's, I do see more under-voltage flashes on my monitors than on my TV's. I hadn't investigated why, but this could explain it.
Alternatively it could be down to back-powering of the Pi through pin 18.
Despite the RT9741CGV, which current limits the pin 18 voltage, often being described as if 'a diode', preventing back-flow of current; the datasheet clearly indicates otherwise. This is why some Pi's remain powered until the HDMI lead is unplugged.
I am not entirely sure what the failure mode would be but back-powering will happen if the monitor is putting out a higher voltage on pin 18 than the Pi's 5V rail. This can happen whenever current draw causes the Pi 5V rail to reduce.
If back-powering occurs it is unlikely a monitor can supply the power a Pi requires which could lead to the Pi's voltage collapsing, until the attached Pi PSU takes over again. It could be the over-current draw which is causing the monitor to momentarily blank, or low-voltage Pi-side.
kartable
Sat Jul 18, 2020 2:15 pm
Removing the keyboad and mouse does help, you're right. But my installation is supposed to get a PS3 eye for voice recording and a speaker.
What would it be if I used a 6V 3A power for all this ? I can't find a 5V 4A which would be probably better.
B.Goode
Sat Jul 18, 2020 2:33 pm
That would probably be a 'pop', or a quiet sigh, maybe some smoke, and your frustrations with this particular board will be over... for good...
- DON'T -
hippy
Sat Jul 18, 2020 2:53 pm
To overcome the monitor issue you might need to run all your USB devices off a powered USB hub. Or multiple powered hubs.
As said; don't even think about a 6V supply. That could destroy your Pi and anything else attached.
A higher current micro-USB 5V PSU may not help due to the polyfuse protection.
Best to try with what you have and a powered USB hub before getting into more complicated solutions.
kartable
Sat Jul 18, 2020 3:21 pm
Thank you for the suggestion, but what kind of powered hub would you see? I have no idea how to connect the usb of screen, ps3eye, speaker and mouse/keyboard through a hub to the pi.
This? https://fr.aliexpress.com/item/33023834 ... hweb201603_
hippy
Sat Jul 18, 2020 5:26 pm
That linked item would probably work but, if the buttons do turn power on and off for the separate ports, that's likely going to prove to be a real pain. That seems designed for charging USB devices rather than connecting USB peripherals.
Any "powered USB hub" without on-off buttons or anything fancy should do the job. Just plug your USB devices into that and it into the Pi.
Sat Jul 18, 2020 5:40 pm
It's AMPS you need not VOLTS.
5V at anything from 3A to 10A will work.
