nekrutnikolai
GPIO - high side switching an LED
Thu Jul 09, 2020 5:49 pm
I can't seem to figure out how to high-switch an LED for a matrix that I'm building. It needs to be high-switchable.
I tried building a Sziklai Pair circuit but it would not with the GPIO as the GPIO isn't strictly an on/off switch. It seems to be too sensitive, I can turn the led on or off using my finger.
Could y'all please point me in the right direction.
drgeoff
Re: GPIO - high side switching an LED
Thu Jul 09, 2020 6:39 pm
I've been in electronics for more than half a century and never before encountered the term "Sziklai Pair". Googled it and found that yes I have used that configuration.
Need more detail (ie schematic) of what you have tried that did not work.
boyoh
Thu Jul 09, 2020 7:02 pm
I might be wrong with this , but it might be like a Darlington Pair configuration. So it might be very sensitive
To lower the sensitivity try a 4k7 resistor from base to ground. Or try other value resistors ( Not to low )
Regards Boyoh
BoyOh ( Selby, North Yorkshire.UK)
Some Times Right Some Times Wrong
pcmanbob
Thu Jul 09, 2020 7:19 pm
Hi.
If you want a high side driver for an LED try this circuit.
nekrutnikolai
Fri Jul 10, 2020 4:16 pm
Hi.
Thanks for the reply.
Would it be possible to power it from an external 5V power supply as I don't want to risk damaging the GPIO, the led's need about 500mA.
nekrutnikolai
Fri Jul 10, 2020 5:24 pm
Hi.
I realized that I can actually power the pi from the GPIO, and the schematic of the circuit that you provided works like a charm.
