tobi89
Older gimp on rpi4
Mon Jul 06, 2020 9:05 pm
Hello.
Is there some easy way to istall older version of gimp (2.8.22) on new raspbian on raspberry pi?
I have some some scripts for automatic image manipulation, but they don't work with the 2.10 which is in the depository.
I tried to compile it from the source, but didn't managed to do it (never done it before though).
PS: Sorry if posted in the wrong section, didn't find any better suited.
B.Goode
Re: Older gimp on rpi4
Tue Jul 07, 2020 12:15 pm
Welcome to the Raspberry Pi forums.
Hello.
I can't answer your question directly. If you have trouble building this package from its source code perhaps the Mailing List for GIMP itself would be a more appropriate source for advice? https://www.gimp.org/mail_lists.html
As an alternative approach, have you considered updating the scripts to be compatible with the current supported version of GIMP, in preference to making yourself dependent on a version of a package that has been superceded by its developers? Again, the dedicated mailing list might be better informed on this subject.
scruss
Tue Jul 07, 2020 12:42 pm
As an alternative approach, have you considered updating the scripts to be compatible with the current supported version of GIMP …
The internal changes from 2.8 to 2.10 were huge. Most scripts would need to be entirely rewritten. A lot of the old scripts I used to rely on have gone away completely. So this isn't a small matter of maintenance.
The good thing about build an older version on a newer Raspberry Pi 4 is that the capabilities will be about matched: the code won't be painfully slow, and the build process might be manageable.
Pronouns: he/him
B.Goode
Tue Jul 07, 2020 12:47 pm
Happy to hear an alternative view supported by experience. Still leaves the substantive question of how to get the old version onto the RPi.
tobi89
Wed Jul 15, 2020 10:13 pm
after some unsuccessful tries with compiling older gimp I've decided to install older distro instead. It wasn't as easy as I thought it would be. Older raspbians didn't work, so I tried Ubuntu mate 18.04 for pi, which should be supported, but that also didn't run on my pi 4. So I ended up with installing server version of ubuntu 18.04, than adding xubuntu desktop on it. But it is finally working! Gimp 2.8 is running on my pi 4 :-)
