Eternyt
Upgrade from PHP 7.0 to 7.3 on Stretch
Fri Jul 03, 2020 2:03 pm
Hi all,
probably a stupid question. Is it possible to upgrade from PHP 7.0 to 7.3, while staying on Stretch? If yes, how I do it?
Thanks!
pidd
Re: Upgrade from PHP 7.0 to 7.3 on Stretch
Fri Jul 03, 2020 2:19 pm
Have you tried installing "php7.3"?
sudo apt-get install php7.3
Fri Jul 03, 2020 2:59 pm
You misread the OPs requirement, PHP 7.0 is the default in Raspbian Stretch, whilst PHP 7.3 is default in RaspiOS (formerly Raspbian) Buster.
Fri Jul 03, 2020 3:05 pm
Hi all,
Thanks!
You will have to build from Source Code, though it may cause dependencies issues:
https://github.com/php/php-src
pidd
Fri Jul 03, 2020 3:15 pm
I admit I didn't read any of that information in the OP's question.
I made a suggestion, just in case the 7.3 package is available even if it isn't the default that would be picked up by an update - I thought I had done similar on Buster at one point.
Are you saying there is 100% no chance that it could happen?
Fri Jul 03, 2020 3:18 pm
The OP is running Raspbian Stretch not Buster :?
Fri Jul 03, 2020 3:22 pm
... while staying on Stretch? ...
What possible reason do you have for that? What's blocking your upgrade to the better supported OS?
pidd
Fri Jul 03, 2020 3:28 pm
I fail to see the significance? Please enlighten me.
Eternyt
Fri Jul 03, 2020 3:33 pm
Thanks for all the answers, so if I get it correctly there are no easy ways to update to PHP 7.3 (or any major version after 7.0).
The reason I do not want to upgrade to Buster is that I have to start from a fresh install so I have to rebuild all of what I have done from scratch. And since I'm using my raspberry as a web server for more than a year now, I don't remember all the things I installed and modified to get all working.
