Need help with everything for a github project.
Posted: Wed Jul 01, 2020 8:49 am
by simonfish
Hello this is my first post so hope its in the correct forum area if not can admin please move it. Hope you can all help me getting this github project working because i`m just getting started with the RPI. I`m trying to do this project in the link here I can`t seem to get it to work i think it may be because its on a older operating system.
I think i need to find out how to get it working on the newest RPI OS that i have downloaded and using a RPI 3.
If you have any advice on converting it to work on the newer RPI OS. please be kind i have no idea what i`m doing yet.
Re: Need help with everything for a github project.
Posted: Wed Jul 01, 2020 9:11 am
by B.Goode
Welcome to the Raspberry Pi forums.
"I can`t seem to get it to work"
What have you tried? How does it seem to fail?
Have you considered asking the author/developer for advice with their own project? https://github.com/martinr1000/AliensMo ... ker/issues
Posted: Wed Jul 01, 2020 9:45 am
by simonfish
I tryed running it in desktop and i get erros in a shell box.
trackback (most recent call last);
file "home/pi/tracker/main.py " line 15, <in module>
from audioimport trackeraudio
file "home/pi/tracker/audio.py "line 6, <in module>
from pyscope import pyscope
file "home/pi/tracker/psscope.py "line27
print driver: {0} failed format driver.
Is there a way to copy the text from my rpi to paste it here insted of typing everything in ?
Posted: Wed Jul 01, 2020 3:45 pm
by B.Goode
How, exactly, are you trying to run the script? It is intended to be run with the python interpreter, which will use the Python2 'dialect' of the language. If you try to run it with the currently recommended Python3 interpreter errors like the one you report might be expected.
Have you taken into account the detailed Installation instructions in the file 'tracker install.txt'?
Posted: Wed Jul 01, 2020 4:09 pm
by dbrion06
Yes: copy and paste works...
The sequence of errors you show is a stack, where the first error is displayed last.
First error which occurs breaks pyscope and is interesting:
line 27 is
 print 'Driver: {0} failed.'.format(driver)
which is part of
        # Check which frame buffer drivers are available
        # Start with fbcon since directfb hangs with composite output
        drivers = ['fbcon', 'directfb', 'svgalib']
        found = False
        for driver in drivers:
            # Make sure that SDL_VIDEODRIVER is set
            if not os.getenv('SDL_VIDEODRIVER'):
                os.putenv('SDL_VIDEODRIVER', driver)
            try:
                pygame.display.init()
            except pygame.error:
                continue
            found = True
            break
Scans for 3 drivers ...
Do you use python3 (print has a different syntax than python 2: your code is obviously for python2)...
Did you read https://github.com/martinr1000/AliensMo ... nstall.txt
BTW: this seems somewhat complicated for 1rst steps with RPi and -perhaps- python
Posted: Wed Jul 01, 2020 4:33 pm
by simonfish
I was hoping someone would know how to get it working on the newer OS. Or if someone could even change if for me to get it working. I have no idea how it all works.
Posted: Wed Jul 01, 2020 4:39 pm
by B.Goode
Presumably the author/developer would know?
Or you could try, at a shell (Terminal or Command Line) prompt -
python main.py
and report back on your success or failure...
Hint: I tried this on a system running RasPiOS Buster before posting the advice... It generates a screen with a semicircular 'scaffolding' with a blue box under it with some incomprehensible numbers. I have no idea what is supposed to happen after that. No changes were needed.
Posted: Wed Jul 01, 2020 5:01 pm
by simonfish
I think your seeing it correctly. I will give it a go at the command line.
Posted: Thu Jul 02, 2020 9:10 am
by simonfish
I gave it a go in the console and i still let errors as above. I typed python /home/pi/tracker/main.py.
I have no idea how to contact the creator via github i dont see any contact infomation.
Posted: Thu Jul 02, 2020 10:26 am
by B.Goode
It isn't clear from what you have written how you have installed the code from the github repository, but you could try -
cd /home/pi/tracker
python main.py
You could try using the explicit link to the repository Issues page that I provided several posts ago...
I don't think I have anything further to contribute so will now withdraw from the discussion.
Posted: Sat Jul 04, 2020 10:35 am
by simonfish
cd /home/pi/tracker
python main.py
Thanks for all the advise .Goode.
I managed to get it working using Buster OS. But it only seems to work if i boot into desktop first. and add this auto start part.:
Auto Startup
1) open lxterminal
2) type the following then press enter:
	sudo nano ~/.config/lxsession/LXDE-pi/autostart
3) add the following at the end of the file
	@sudo python2 /home/pi/tracker/main.py
But it will not boot up if i add the auto start but boot into terminal. Do you know how i can get it to boot up using the terminal. the error is listed below.
pi@raspberrypi:~ $ cd /home/pi/tracker
pi@raspberrypi:~/tracker $ python main.py
pygame 1.9.4.post1
Hello from the pygame community. https://www.pygame.org/contribute.html
Driver: fbcon failed.
Driver: directfb failed.
Driver: svgalib failed.
  File "main.py", line 59, in <module>
    scope=pyscope()
  File "/home/pi/tracker/pyscope.py", line 33, in __init__
    raise Exception('No suitable video driver found!')
Exception: No suitable video driver found!
pi@raspberrypi:~/tracker $ fbconfbcon
