Pi hole problem with connection
Posted: Sat Jun 27, 2020 5:51 pm
by kasek
So I’ve had my puhole running for a few months now no issues. Last night all of a sudden I had no internet on my phone or iPad. I changed my DNs back to the automatic and worked fine. I was checking on the pi this morning and found it had shut it self down or got turned off, I rebooted and now it won’t connect to wifi. I’ve tried reentering the password but it just keeps trying to connect any ideas?
Re: Pi hole problem with connection
Posted: Sat Jun 27, 2020 8:30 pm
by pcmanbob
I would suggest you shut the pi down and any other PC / device then reboot your router , let it complete the reboot then try your pi again.
Posted: Sat Jun 27, 2020 9:10 pm
by kasek
Ok I’ll give that a try when I get home thanks, I had rebooted the pi not the router. It’s weird though because every other device connects no problem
Posted: Sun Jun 28, 2020 12:32 am
by kasek
pcmanbob wrote: ↑Sat Jun 27, 2020 8:30 pm
Rebooted pi, router and my pc same thing the wifi icon just flashes up the bars like it’s trying to connect but never does. And websites say the site can’t be reached
Edit: if I connect to the upstairs wifi network it’ll connect the zero to wifi but then the pie hole doesn’t work. When I change my DNs on the iPad the internet stops working on the iPad.
Posted: Sun Jun 28, 2020 6:02 am
by pcmanbob
If you have 2 wifi networks did you reboot both access points and the router ?
Posted: Sun Jun 28, 2020 4:41 pm
by kasek
pcmanbob wrote: ↑Sun Jun 28, 2020 6:02 am
I did yes
Posted: Sun Jun 28, 2020 5:41 pm
by pcmanbob
If you can connect to the other WiFi network then it suggests that your pi's WiFi is working.
You might try renaming your your wpa_supplicant to some thing else and creating a new one just incase it had become corrupted when your pi was switched off suddenly.
Posted: Tue Jun 30, 2020 1:08 am
by kasek
pcmanbob wrote: ↑Sun Jun 28, 2020 5:41 pm
I thought I might have to reset the whole thing..... was hoping that wasn’t the case
