Pi hole problem with connection
So I’ve had my puhole running for a few months now no issues. Last night all of a sudden I had no internet on my phone or iPad. I changed my DNs back to the automatic and worked fine. I was checking on the pi this morning and found it had shut it self down or got turned off, I rebooted and now it won’t connect to wifi. I’ve tried reentering the password but it just keeps trying to connect any ideas?
Re: Pi hole problem with connection
I would suggest you shut the pi down and any other PC / device then reboot your router , let it complete the reboot then try your pi again.
Ok I’ll give that a try when I get home thanks, I had rebooted the pi not the router. It’s weird though because every other device connects no problem
Rebooted pi, router and my pc same thing the wifi icon just flashes up the bars like it’s trying to connect but never does. And websites say the site can’t be reached
Edit: if I connect to the upstairs wifi network it’ll connect the zero to wifi but then the pie hole doesn’t work. When I change my DNs on the iPad the internet stops working on the iPad.
If you have 2 wifi networks did you reboot both access points and the router ?
If you can connect to the other WiFi network then it suggests that your pi's WiFi is working.
You might try renaming your your wpa_supplicant to some thing else and creating a new one just incase it had become corrupted when your pi was switched off suddenly.
I thought I might have to reset the whole thing..... was hoping that wasn’t the casepcmanbob wrote: ↑Sun Jun 28, 2020 5:41 pmIf you can connect to the other WiFi network then it suggests that your pi's WiFi is working.
I switched to a new wifi network so I decided to freshen up my pi by doing a clean os install and new pi-hole install... and I am having the exact same issue. I even re-imaged my pi zero w, reinstalled pi-hole... Works fine until it's restarted the first time. Perhaps it's a bug in the latest release?
