Dear Reader,
I have a 3D printer and decided to install OctoPrint on a Raspberry Pi. Installing was an easy task with a lot of tutorials available.
In OctoPrint I'm making time lapses (Octolapse) using the Raspberry Pi Camera.
Because of an indoor environment I decided to add a "Bright Pi" led&Ir module, which seemed easy to use.
There are however 2 issues.
1. I can't seem to get the resolution up to 1920x1080
2. I have NO experience with Raspberry Pi, Python and all the other things needed to get the Brigth Pi module to work.
I can login to the Pi via SSH, run the brigthpi-test.py, which runs a little program turning different lights on and off.
I just want everything to be on when I turn the system on, but don't have the skill to implement that.
The script is installed via:
curl -sSL https://pisupp.ly/brightpicode | bash
While trying to figure out:
https://github.com/PiSupply/Bright-Pi
But I am to inexperienced to get it to work.
Is there anyone with the knowledge or having the same problem I have?
Would appreciate the help!
Cheers,
Kris
