how to receive data from mqtt and open cv video stream at the same time
Posted: Thu Jun 25, 2020 12:51 pm
My project need to receive mqtt data and videostream data at the same time. However, when my raspi receiving video data by open cv, it cant receive iOT data at the same time. (now i can do it seperately
My raspi need to check if the iot data is on, and the video will not turn on and receive data.
So the piority is
iOT sensor check if there is something detected-----> video will not turn. (case 1)
iOT sensor check if there is nothing detected-------> video turn on and receive another image data. (case 2)
Here is how i get the iot sensor data by mqtt
Here is how my raspi get the videostream data by openCV
I want to keep the Exit function if i press the "q" from my keyboard
So the piority is
# Main template for our paho.mqtt.client code
# lets obtain potentiometer reading from ESP8266
# listen to topic "/esp/pot"
import paho.mqtt.client as mqtt
# The callback for when the client receives a CONNACK response from the server.
def on_connect(client, userdata,flags, rc):
print("Connected with result code "+str(rc))
# Subscribing in on_connect() means that if we lose the connection and
# reconnect then subscriptions will be renewed.
client.subscribe("/esp/pot") # remember this topic to put inside ESP code later
# The callback for when a PUBLISH message is received from the server.
def on_message(client, userdata, msg):
cX=int(msg.payload)
print(cX)
client = mqtt.Client()
client.on_connect = on_connect
client.on_message = on_message
client.connect("localhost", 1883, 60) # localhost is the Raspberry Pi itself
# Blocking call that processes network traffic, dispatches callbacks and
# handles reconnecting.
# Other loop*() functions are available that give a threaded interface and a
# manual interface.
client.loop_forever()Code: Select all
# USAGE
# python ball_tracking.py --video ball_tracking_example.mp4
# import the necessary packages
from collections import deque
from imutils.video import VideoStream
import numpy as np
import argparse
import cv2
import imutils
import time
import serial
import struct
# construct the argument parse and parse the arguments
ap = argparse.ArgumentParser()
ap.add_argument("-v", "--video",
help="path to the (optional) video file")
ap.add_argument("-b", "--buffer", type=int, default=0,
help="max buffer size")
args = vars(ap.parse_args())
# define the lower and upper boundaries of the "green"
# ball in the HSV color space, then initialize the
# list of tracked points
greenLower = (25, 96, 49)
greenUpper = (39, 255, 255)
pts = deque(maxlen=args["buffer"])
ser = serial.Serial('/dev/ttyACM0',9600)
# if a video path was not supplied, grab the reference
# to the webcam
if not args.get("video", False):
vs = VideoStream(src=0).start()
# otherwise, grab a reference to the video file
else:
vs = cv2.VideoCapture(args["video"])
# allow the camera or video file to warm up
time.sleep(2.0)
# keep looping
while True:
# grab the current frame
frame = vs.read()
# handle the frame from VideoCapture or VideoStream
frame = frame[1] if args.get("video", False) else frame
# if we are viewing a video and we did not grab a frame,
# then we have reached the end of the video
if frame is None:
break
# resize the frame, blur it, and convert it to the HSV
# color space
frame = imutils.resize(frame, width=248)
blurred = cv2.GaussianBlur(frame, (11, 11), 0)
hsv = cv2.cvtColor(blurred, cv2.COLOR_BGR2HSV)
# construct a mask for the color "green", then perform
Lower = greenLower
Upper = greenUpper
mask = cv2.inRange(hsv, Lower, Upper)
mask = cv2.erode(mask, None, iterations=2)
mask = cv2.dilate(mask, None, iterations=2)
# find contours in the mask and initialize the current
# (x, y) center of the ball
cnts = cv2.findContours(mask.copy(), cv2.RETR_EXTERNAL,
cv2.CHAIN_APPROX_SIMPLE)
cnts = imutils.grab_contours(cnts)
center = None
# only proceed if at least one contour was found
if len(cnts) > 0:
# find the largest contour in the mask, then use
# it to compute the minimum enclosing circle and
# centroid
c = max(cnts, key=cv2.contourArea)
((x, y), radius) = cv2.minEnclosingCircle(c)
M = cv2.moments(c)
cX = int(M["m10"] / M["m00"])
cY = int(M["m01"] / M["m00"])
center = (cX, cY)
# only proceed if the radius meets a minimum size
if radius > 2:
cv2.circle(frame, center, 5, (0, 0, 255), -1)
print (cX)
if len(cnts) == 0:
cX = 249
print (cX)
# show the frame to our screen
cv2.imshow("Frame", frame)
chkKey = cv2.waitKey(1) & 0xFF
# if the 'q' key is pressed, stop the loop
if chkKey == ord("q"):
cX = 0
break
# if we are not using a video file, stop the camera video stream
vs.stop()
# otherwise, release the camera
else:
vs.release()
# close all windows
cv2.destroyAllWindows()I want to keep the Exit function if i press the "q" from my keyboard
