fred7
Easiest way to generate graph from temperature data
Wed Jun 24, 2020 2:27 pm
Hello!
Does anyone know what is the easiest method to generate graph from temperature log file?
The file I have (temperature.txt):
24/06/20 03:05 21.62
24/06/20 03:06 21.63
24/06/20 03:07 22.39
I have tried using Gnuplot and Rrdtool. But these fail. I am using only console through SSH. I would like just to generate basic XY-graph and save it to file (graph.jpg).
JovianPyx
Re: Easiest way to generate graph from temperature data
Wed Jun 24, 2020 2:42 pm
I use gnuplot to generate a png file from the data which is then available to apache2. Since the webpage auto-refreshes, the graph is "live" given some latency.
Alternatively, I have used KO18-U translation on a puTTY terminal which has two half block characters that I use as huge pixels. I wrote a C program that reads the temperature and displays it as a live updating coarse graph. That is good enough to display the temperature (in C) in 1/2 degree increments on a terminal with about 100 lines. This method displays in the terminal in which it is run and needs no webserver. The downside is the translation makes other things look weird unless you change it back to UTF-8 or whatever your default is. I color the "pixels" green except when above 70C they are yellow and red when 80C or more (which I fortunately never see).
gordon77
Wed Jun 24, 2020 4:03 pm
try this... (based on https://learn.sparkfun.com/tutorials/gr ... -real-time )
data in file called temp_data.txt
import datetime as dt
import matplotlib.pyplot as plt
import matplotlib.animation as animation
# Create figure for plotting
fig = plt.figure()
ax = fig.add_subplot(1, 1, 1)
xs = []
ys = []
graph_data = open('temp_data.txt','r').read()
lines = graph_data.split('\n')
xs = []
ys = []
for line in lines:
    if len(line) > 1:
        d, t, y = line.split(' ')
        xs.append(d + " " + t)
        ys.append(float(y))
# This function is called periodically from FuncAnimation
def animate(i, xs, ys):
    # Limit x and y lists to 20 items
    xs = xs[-20:]
    ys = ys[-20:]
    # Draw x and y lists
    ax.clear()
    ax.plot(xs, ys)
    # Format plot
    plt.xticks(rotation=45, ha='right')
    plt.subplots_adjust(bottom=0.30)
    plt.title('Temperature over Time')
    plt.ylabel('Temperature (deg C)')
# Set up plot to call animate() function periodically
ani = animation.FuncAnimation(fig, animate, fargs=(xs, ys), interval=1000)
plt.show()
neilgl
Wed Jun 24, 2020 4:34 pm
That is odd, I used rrdtool to plot graphs of temperature for many years, all OK. What is failing when you use rrdtool?
B.Goode
Wed Jun 24, 2020 5:29 pm
Discussed in a parallel universe, here - viewtopic.php?f=91&t=278239&p=1684888#p1684888
bensimmo
Wed Jun 24, 2020 7:56 pm
stick it in excel/sheet/spreadsheet on the pi.
select all the data, hit graph ?
EDIT: I 'll leave it up, but just reread and you're using console. my bad.
scruss
Wed Jun 24, 2020 9:55 pm
How is gnuplot failing? Something like this should work, or at least produce some output:
set terminal jpeg size 720,405
set output "graph.jpg"
set xdata time
set timefmt "%y/%m/%d %H:%M"
plot "temperature.txt" using 1:3
Pronouns: he/him
fred7
Wed Jun 24, 2020 10:08 pm
Update.
I tried using matplotlib and numpy. Again no luck.
Used this python script, and launched it using command ("sudo python numpy.py")
import numpy as np
data = np.loadtxt('data.txt')
x = data[:, 2]
y = data[:, 3]
plt.plot(x, y,'r--')
plt.savefig('graph.png')
Error: ImportError: No module named matplotlib.pyplot
neilgl
Wed Jun 24, 2020 11:20 pm
scruss
Wed Jun 24, 2020 11:23 pm
sudo apt install python3-matplotlib python3-numpy
then do
python3 numpy.py
(no sudo required - you don't need sudo)
But maybe don't call it numpy.py as then Python might get confused with the numpy package.
Pronouns: he/him
bensimmo
Thu Jun 25, 2020 7:26 am
you would need to use python3 to run Python3 code under RPiOS
scruss
Thu Jun 25, 2020 1:26 pm
yep, typo on my part
Pronouns: he/him
jbudd
Thu Jun 25, 2020 5:03 pm
Here is a Node-Red flow to:
- Read your data from /home/pi/data.txt,
- Convert the date and time to a javascript date object,
- Display a graph as a .png file on a web page at <Pi ip address>:1880/ui
You don't need a web server on the Pi, it's built in to Node-Red
The flow uses node-red-dashboard and node-red-contrib-moment which you have to install via hamburger menu | Manage palette.
[{"id":"6eca75c8.edf524","type":"ui_chart","z":"764a32e2.a1ee5c","name":"","group":"490e9b00.e9d99c","order":1,"width":0,"height":0,"label":"Temperatures","chartType":"line","legend":"false","xformat":"auto","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":760,"y":180,"wires":[[]]},{"id":"490e9b00.e9d99c","type":"ui_group","z":"","name":"Original","tab":"5b74fd34.5b4414","disp":true,"width":"7","collapse":false},{"id":"5b74fd34.5b4414","type":"ui_tab","z":"","name":"Foo","icon":"dashboard","order":4,"disabled":false,"hidden":false}]
Untitled 1.jpg (34.04 KiB) Viewed 313 times
With just the three data points you shared, it displays this graph.
scruss
Thu Jun 25, 2020 6:26 pm
OP is using console through SSH, so no hamburgers there.
Pronouns: he/him
jbudd
Thu Jun 25, 2020 6:44 pm
Yes, I saw that. My suggestion requires another computer with browser on the same network to access the Pi. I use a laptop.
