jahboater
Re: ftp server - unable to upload files
Wed Jun 24, 2020 7:59 am
david_1234 wrote:
Wed Jun 24, 2020 6:37 am
I hav edone this at before
sudo mkfs -t ext4 /dev/sda1
and someone here told me it's not OK
Who said that and why ?
This is the newer command, but its just the same in practice.
sudo mkfs.ext4 /dev/sda1
Pi4 8GB running PIOS64
david_1234
Wed Jun 24, 2020 9:26 am
this is what I'm getting
pi@raspberrypi:~$ sudo mkfs.ext4 /dev/sda1
mke2fs 1.44.5 (15-Dec-2018)
/dev/sda1 contains a vfat file system labelled 'UBUNTU 16_0'
Proceed anyway? (y,N) y
/dev/sda1 is mounted; will not make a filesystem here!
Wed Jun 24, 2020 9:51 am
Unmount the filesystem and try again. It cannot be formatted if it is in use.
Unreadable squiggle
david_1234
Wed Jun 24, 2020 10:25 am
OK
now it'w working and I can change the permission - thanks
pi@raspberrypi:~$ sudo chmod 777 -R /mnt/mydisk/
camera/     lost+found/ pi/
pi@raspberrypi:~$ ls -ls /mnt/mydisk/camera/
total 4
4 drwxrwxrwx 2 pi pi 4096 Jun 24 13:20 ftp
I will start work on the ftp server and see if It's work as planed now
Thank you for the help!
thagrol
Wed Jun 24, 2020 10:36 am
Setting aside all arguments about which file system is best try this:
  1. Plug in your USB stick
  2. Find the required information about it:
    1. Run
      sudo blkid
    2. Make a note of the TYPE, UUID, and PARTUUID e.g.
      • TYPE="vfat"
      • UUID="123456"
      • PARTUUID="654321"
  3. If TYPE="ntfs" run the following with while your Pi is able to access the internet:
    sudo apt update && sudo apt install -y ntfs-3g
  4. If TYPE="exfat" run the following with while your Pi is able to access the internet:
    sudo apt update && sudo apt install -y exfat-fuse exfat-utils
  5. Decide where you want it to appear in your file tree (i.e. decide on a mount point)
  6. Create the mount point:
    mkdir -p /path/to/mount_point
    You may need to prefix that with sudo depending on where your chosen mount point is located.
  7. Make a backup copy of /etc/fstab:
    sudo cp /etc/fstab /etc/fstab.bak
  8. Open /etc/fstab in your preferred text editor. You will need to be root or use "sudo" to do this.
  9. If you have a line from previous attempts to mount this device, remove it.
  10. Refering to the information gathered above add a new line/entry for the device, use either PARTUUID or UUID:
    • For vfat filesystem:
      PARTUUID=654321 /path/to/mount_point vfat defaults,nofail,noatime,umask=000 0 0
    • For exFAT filesystem:
      PARTUUID=654321 /path/to/mount_point exfat defaults,nofail,noatime,umask=000 0 0
    • For other filesystems:
      PARTUUID=654321 /path/to/mount_point TYPE defaults,nofail,noatime 0 0
      Where TYPE is the TYPE reported by blkid, above.
  11. Save and close /etc/fstab
  12. Reboot or run
    sudo mount -a
Edit: seems the OP fixed their issue while I was writig this post. Gonna leave it here as it may be useful to others.
Edit #2: added notes on exFAT
Attempts to contact me outside of these forums will be ignored unless signed in triplicate, sent in, sent back, queried, lost, found, subjected to public enquiry, lost again, and finally buried in soft peat for three months and recycled as firelighters
david_1234
Wed Jun 24, 2020 2:03 pm
it's seem like a good guide for first time user!
great!
