brettsalyer
HDMI to VGA convert adapter. Will this work?
Mon Dec 31, 2012 5:12 pm
I have an older monitor and need a HDMI to VGA adapter. I know certain ones wont work.
Ii was wondering if this: http://www.amazon.com/Black-Input-Adapt ... B007KFVQXI
will work. It looks like it might.
poing
Re: HDMI to VGA convert adapter. Will this work?
Mon Dec 31, 2012 5:23 pm
The problem some people reported seems related to a power issue, in that the adapter draws too much current. Here's one that is tested with the Pi rev2 boards (albeit more expensive): http://www.newit.co.uk/shop/proddetail. ... ter&cat=13. It looks the same btw ;)
brettsalyer
Mon Dec 31, 2012 5:32 pm
Thanks, but i was looking for something slightly cheaper. (Even though that is pretty cheap) ;)
g4eml
Mon Dec 31, 2012 9:05 pm
The two devices above are the same thing, just different colour cases. They both use the same chip. I have been using one of the black ones for over six months with no problems. However as mentioned elsewhere they both take more current from the HDMI port than it is designed to give so there is a small risk involved in using them.
johnbeetem
Mon Dec 31, 2012 11:01 pm
There's a good list of adapters, success stories, caveats, and configuration settings at the RasPi Wiki:
http://elinux.org/RPi_VerifiedPeriphera ... rter_boxes
http://elinux.org/RPi_Screens#RGB_analog.2FVGA
Unpowered adapters may burn out diode D1, or your D1 may be strong enough to handle the power required by the adapter. Or D1 may fail by shorting out, in which case it will seem to work but may cause problems later if you hook up to another HDMI device.
