MarkIpswich
USB Audio Adapter for Zero W. How to get sound from it.
Mon Jun 15, 2020 1:45 pm
I just got one of these (not the official one) for the pirate radio and I will be using it so I can listen to it via headphones.
How do I enable this to work please?
I looked at a lot of stuff and all I am getting is how to change it from HDMI to 3.5mm jack.
Thank you.
LTolledo
Re: USB Audio Adapter for Zero W. How to get sound from it.
Mon Jun 15, 2020 2:30 pm
Either you extract it using a few passive components
or use a DAC audio board designed for the RPiZW
Like the pimoroni pHAT DAC
Some people be like:
MarkIpswich
Mon Jun 15, 2020 2:38 pm
I do have it set up so I can listen to it via the built in speaker, however I just want to know how to enable the USB Audio Adapter in the desktop PI so I can listen to it via headphones.
I need to know the instructions please.
Thank you.
Mon Jun 15, 2020 3:16 pm
Thank you.
If you are running a fully updated Raspberry Pi OS (formerly Raspbian Buster) with Desktop you can use the Applet to change Audio Defaults:
https://www.raspberrypi.org/blog/latest ... -may-2020/
RPi 4B 4GB (SSD Boot)..
MarkIpswich
Mon Jun 15, 2020 3:25 pm
Using a 2018 version.
You mean the bit on there where it says about creating a ".asoundrc" file?
Can USB Type-A work or must the adapter be the "C" version?
Mon Jun 15, 2020 4:10 pm
What has this to do with USB Audio Adaptor ?
neilgl
Mon Jun 15, 2020 4:17 pm
What make of USB Audio Adapter is it?
MarkIpswich
Mon Jun 15, 2020 4:18 pm
Doesn't matter.
How do I get the applet bit then. I've never done it before.
It's this one
https://www.amazon.co.uk/gp/product/B00 ... UTF8&psc=1
LTolledo
Mon Jun 15, 2020 5:09 pm
right click the speaker icon that appears in the top right of your monitor (just like the one shown above)
from there you should be able to see
Analog
HDMI
USB audio
select the USB audio
sometimes you may or may not need to reboot to have it activate.
neilgl
Mon Jun 15, 2020 6:52 pm
How is that USB adapter (type A) for headphones/mic connected to the microUSB on the pizero?
MarkIpswich
Mon Jun 15, 2020 7:34 pm
USB A (female) to micro B (male) adaptor
The white one that came with the pirate radio.
HawaiianPi
Mon Jun 15, 2020 10:11 pm
Doesn't matter.
It does matter, because the USB audio adapter must be supported in Linux.
Just right-click on the volume control on the right side of the panel, and choose your audio device.
The name of your audio device might be different from mine.
EDIT: updated picture.
neilgl
Mon Jun 15, 2020 10:23 pm
Ah, the “white one that came with the pirate radio” where did that pirate radio kit come from?
Tue Jun 16, 2020 6:26 am
This one: https://shop.pimoroni.com/products/pira ... roject-kit
LTolledo
Tue Jun 16, 2020 12:53 pm
my RPiZW setup with the "white cable" (but this cable didn't come from Pimoroni)
RPiZW USB audio with white cable view1.jpg (176.83 KiB) Viewed 454 times
RPiZW USB audio with white cable view2.jpg (162.13 KiB) Viewed 454 times
and this is how I setup the audio out
RPiZW RPiOS USB audio selection.jpg (38.87 KiB) Viewed 454 times
sound did come out from my in-ear phones. (when I played some YT video)
neilgl
Tue Jun 16, 2020 12:57 pm
Ah that kit looks like it uses Raspbian Lite so there won’t be any GUI to set the audio output device.
MarkIpswich
Tue Jun 16, 2020 2:11 pm
So you saying it won't work?
Haven't done it yet as waiting on something else that I ordered.
Tue Jun 16, 2020 2:17 pm
We appear to be going round in circles, mis-information rules, maybe this should clarify ?
https://www.raspberrypi-spy.co.uk/2019/ ... pberry-pi/
MarkIpswich
Tue Jun 16, 2020 2:37 pm
Thank you.
It says latest version it auto picks it up and I am using (I think) as far as I remember, the last updated version of 2018. Does it auto pick it up in that version also?
Tue Jun 16, 2020 3:38 pm
Thank you.
Do yourself and for everyone elses sanity a favour and use the latest release of Raspberry Pi OS (formerly Buster) which was released June 2019....
MarkIpswich
Thu Jun 25, 2020 7:12 pm
It had to be from an old version (Raspbian Stretch 2018) as VLC doesn't work on most versions I tried, then once that was setup, I upgraded to latest version, Raspbian OS.
Done exactly what the instructions says on https://www.raspberrypi-spy.co.uk/2019/ ... pberry-pi/
Still getting sound from the speaker and not in the headphones.
The image will give more info.
https://ibb.co/dpyfcCv
https://ibb.co/8K7M2F7
I selected them controls in the audio settings but nothing.
I know the device does work as it gives that sound when plugging in the headphones.
I've tried many other ways. The output is not muted.
Any ideas with the full commands please. Thank you.
Tried testing sound but nothing.
Also this:
Output stuck muted while Master is toggled
In setups with multiple outputs (e.g. 'Headphone' and 'Speaker') using plain amixer to toggle Master can trigger PulseAudio to mute the active output too, but it does not necessarily unmute it when Master is toggled back to be unmuted. [1] To resolve this, amixer must have the device flag set to 'pulse':
$ amixer -D pulse sset Master toggle
BUT...
ALSA lib control.c:1373:(snd_ctl_open_noupdate) Invalid CTL pulse
amixer: Mixer attach pulse error: No such file or directory
