I would just like to keep one OS on one SD card, and not have multiple OS, just keeps things simple I think.procount wrote: ↑Fri Jun 19, 2020 9:16 amRpi Imager is an OS installer that runs on Windows, Mac or lInux (ie. your existing "PC" computer).
You use it to burn an image file of an OS to an SD card so that you can run it on your Pi.
If you want to install another OS, you need to remove your SD card from the Pi, and reinstall another OS on it using RPI imager on your "PC".
PINN is also an OS installer (amongst other things). But it runs on the Pi itself, not on your "PC".
So you can use RPi Imager on your PC to install PINN onto your SD card like any other OS. When PINN is running on your SD card on the PI, you can use it to download multiple OSes from the internet directly to your SD card without requiring your "PC" (or you can install an OS locally from USB drives).
If you install multiple OSes using PINN, then PINN also becomes a boot manager/os switcher so you can decide which OS to run each time you boot your Pi.
PINN has quite a large catalog of OSes that it can install. You can add other OSes to it yourself, but OSes need a bit of conversion first.
RISCOS is one such OS that it can install, but it is quite an old version. Due to the file format/partitions that RISCOS uses, it is quite special, hence why it has not been updated in a while (needs the help of the original devs to do that). So you can use PINN to run RasPIOS and RISC-OS on the same SD card if you want to (just check which version of RPi this RISCOS can run on first)
However, re-reading your posts, your main requirement seems to be to to run BeebEm, to emulate using the BBC Micro
I would therefore suggest you have a look at https://www.riscosdev.com/direct/
This has probably the most comprehensive & authentic set of BBC Micro emulators on it.
It is not available under PINN, so you would have to burn it direct to your SD card using RPi Imager.
Reference with PINN, sounds a little complicated, or is it just me. With the RISC OS image downloaded can you simply burn it direct or must you use PINN.
If I have to use PINN, is there a step by step guide on how to do this.
One thing that I would very much like to do is to have The BBC Micro Emulator up and running on RISC OS, at the same time would also like to get BeebEm running on RPiOS.
