S-video / composite in on RPi 4 or Zero W
Posted: Thu Jun 11, 2020 7:03 am
by henninghov
I have a project where I am aiming at video transfer between two RPi´s using a 5.8ghz FPV transmitter and receiver. On the RPi Zero W there is an analogue video / TV out that I will use for the transmitter but I am having a hard time to find a way to get analogue video in on the RPi (RPi4 or Zero W) I would like to use a 5.8ghz FPV receiver from Boscam but that is not a must. I see that Auvidea har a few HDMI boards and PiCapture has a board supporting progressive video but I have not found anything with analogue / composite video. Preferably using the Picamera connection. Any advice is appreciated.
Thanks a bunch!
Re: S-video / composite in on RPi 4 or Zero W
Posted: Thu Jun 11, 2020 7:20 am
by fruitoftheloom
Thanks a bunch!
https://linuxtv.org/wiki/index.php/Easycap
Posted: Thu Jun 11, 2020 7:35 am
by henninghov
Thanks for this. I am hoping for a more embedded approach than EasyCap though
Posted: Thu Jun 11, 2020 8:32 am
by PiGraham
Old topic but may have some useful info:
viewtopic.php?f=91&t=141211
Posted: Thu Jun 11, 2020 8:40 am
by henninghov
That is where I started but that thread did not seem to be concluded but thanks a lot
Posted: Thu Jun 11, 2020 9:03 am
by fruitoftheloom
As you have already found input devices are HDMi or NTSC/PAL. Apart from the USB Easycap I am not aware of any other Composite Input solution.
Posted: Thu Jun 11, 2020 10:43 am
by 6by9
Not off the shelf, but the Analog Devices ADV7282-M chip does analogue video (composite, S, or component) to CSI2, andd is supported by the kernel drivers.
I'm not aware of a commerically available board for it beyond the Eval board
Posted: Thu Jun 11, 2020 12:46 pm
by PiGraham
Posted: Thu Jun 11, 2020 1:27 pm
by trejan
There are FPV receivers with a built-in USB capture device.
Posted: Thu Jun 11, 2020 1:49 pm
by PiGraham
Good point!
And cheap too.
https://www.amazon.co.uk/Receiver-Plast ... B07NT2NJ7M
UVC so shouldn't need a driver.
Not a recommendation, just a search result.
