kartable
Berryboot and partitions
Tue Jun 02, 2020 9:02 am
Hi to all,
I have ordered a brand new Pi 3B+ and I am preparing a HDD with several partitions. One of them should include Berrybbot so that I can use more than one OS. Then I will not boot from any SSD but directly from the HDD.
I understand that Berryboot will need formatting and I have already prepared this step with one clean ext4 partition. Wether Berryboot will offer to use this partition ? I hope at least it will not repartition the whole disk where I have stored some data.
Alternatively, I will use a SSD without the HDD, but that's another question. I will eventually boot from the SDD with just raspbian. Wether it makes a difference if I start with my installation with Berryboot first or with this SSD? I heard about something happening on the very first boot with the PI but I am not sure of what it is.
kartable
Re: Berryboot and partitions
Sun Jun 07, 2020 3:31 pm
It seems that Berryboot is not happy. It claims that it there is no partition to mount.
At least this is what I understand from a truncated screen:
"... finding or mounting boot partition :-( "
I have tested with and without the HDD connected on one of the USB outputs. It doesn't make any difference in the message, but I can hear there is an access to the HDD (good sign? It sounds like a beep).
Berryboot is on a USB flash drive apart from the HDD. I thought it would offer at least the opportunity to use the flash drive.
So what? The flash drive is too small? Too many partitions on my HDD? I have NTFS, FAT32 and EXT4, so there is a choice...
(I tested my Pi arrived yesterday with Raspbian on a SSD and everything was fine)
bobmcswain
Wed Sep 23, 2020 3:13 am
Did you find a solution? I'm trying to boot off a thumbdrive with Berryboot copied to it. RPi4 see it (flashing td light) but cannot find a boot partition.
Berryboot works great booting off microsd with the OS repository on thumbdrirve. I want it all on USB-3 connected drive(td or ssd)
Thanks.
Bob
