Filtering data in file...
Posted: Fri May 29, 2020 3:26 pm
by 4k3or3et
HI All
i have a file like this:
one five
two four
three one
*four five
five two
What i am trying to achieve is to add star to beginning of every line which contains sting 'five' but not to the one which already the star at the beginning. Anybody could help?
Re: Filtering data in file...
Posted: Fri May 29, 2020 3:30 pm
by deepo
HI All
one five
two four
three one
*four five
five two
School assignment?
What tools have you been taught that could solve this?
/Mogens
Posted: Fri May 29, 2020 3:33 pm
by rpdom
There would be lots of ways to do that. You could write code in Python3, or C, or even bash. It would be a one-liner in sed (which would be my choice).
Posted: Fri May 29, 2020 3:35 pm
by B.Goode
… or [g]awk or PERL.
Posted: Fri May 29, 2020 5:13 pm
by 4k3or3et
Thank you for all replies. It has to be done in Bash. Preferably 'sed' command if possible...
Posted: Fri May 29, 2020 6:27 pm
by bjtheone
I would start with:
man sed
Posted: Fri May 29, 2020 6:34 pm
by DougieLawson
So what have you tried? Have you got a working regex for it? If not, how does it fail? What part of the failure are you struggling with?
Posted: Fri May 29, 2020 7:53 pm
by 4k3or3et
Thaks again for all replies
i stuck with this:
sed -i 's/.*five/*&/' filename
it adds star to beginning of each line containing string 'five'.
The problem is that it adds star also to the lines which already has start at the beginning. I can't figure out how to exclude lines with '*'...
Posted: Fri May 29, 2020 7:59 pm
by jahboater
Perhaps insert
at the start ?
Posted: Fri May 29, 2020 8:01 pm
by DougieLawson
Use
/^five/
to force it to look at the start of the line.
Posted: Fri May 29, 2020 8:04 pm
by bjtheone
Look up anchoring your regexs.
"/^five" does not work for the data line "four five"
Posted: Fri May 29, 2020 8:06 pm
by DougieLawson
I don't want to, but the OP will learn more by trying mine and seeing how that fails. Your answer is arcane without a complex explanation.
Posted: Fri May 29, 2020 8:16 pm
by jahboater
To the OP, if you worked out that sed command yourself then I think you have a pretty good understanding of things!
Here is a bit more.
^ at the start of an RE says to constrain the match to the start of the line (called anchoring it). Similarly $ anchors to the end of the line.
so for example ^hello$ matches lines containing only the word hello, and ^$ matches the empty line.
[abc] is a character class that matches either a or b or c
[^abc] inverts the class matching anything except a or b or c
[^*] therefore matches anything except *
Putting the two together, ^[^*] matches any line not starting with * which is what you want.
sed -i 's/^[^*].*five/*&/' filename
You could extend it with \<five\> where \< matches the start of a word and \> matches the end of a word.
This would exclude thing like abcfive.
Posted: Fri May 29, 2020 8:47 pm
by 4k3or3et
Thank you.
However:
sed -i '/*/!s/.*five/*&/' filename
seems to work fine in my case. No start are duplicated anymore...
Posted: Fri May 29, 2020 11:24 pm
by bjtheone
I suspect the first hit one gets if you put "anchoring regex" into Google would then be very illuminating. The "Look up" was in an extra handy hint to do that. :-)
https://www.regular-expressions.info/ is a good place to wander around for some basic learning.
