RPI3B+ not booting up from Micro SD
Posted: Sun May 24, 2020 10:51 am
by pratt
Re: RPi3B+ not booting after change boot order
Hi My RPI3B+ is not booting up from Mico SD card, after coding it to boot from USB. I believe the USB was not right, .
How to reset the RPI3B+ to factory reset.
The green and red lights are flashing, to confirm the power and activity happening with the RPI.
Re: RPI3B+ not booting up from Micro SD
Posted: Sun May 24, 2020 12:53 pm
by wildfire
OTP bits (ONE TIME Programmable) cannot be reset, however the 3b+ should have came from the factory floor with the relevant bit set, only the 3b may (or may not) need this set.
In effect your 3b+ is already at factory settings unless you've messed around with the other OTP memory, I feel that your problem lies elsewhere.
EDIT: The red light should not be flashing.
Posted: Sun May 24, 2020 1:04 pm
by fruitoftheloom
viewtopic.php?f=28&t=58151
Red light should be solid, Power Supply ?
https://www.raspberrypi.org/documentati ... /README.md
https://www.raspberrypi.org/documentati ... g-icons.md
