thesisPi20
Socket communication among multiple Raspberry Pis
Fri May 22, 2020 6:15 pm
Hi all,
As the title says, I need to create a system with multiple Raspberry Pis that the Pis can send simple socket messages among them. Do you have any suggestion how I can start this? Here are what I thought I can do:
1) Setup a mesh network and then start socket messaging.
2) Use TCP connection to start socket messaging without setting up a mesh network. I found sources mostly between PC and the Pi. No luck Pi-Pi so far.
Do you guys have any suggestions where I can start? I will appreciate any hint and help!
B.Goode
Re: Socket communication among multiple Raspberry Pis
Fri May 22, 2020 6:32 pm
Hi all,
Do you have to implement this with your own low-level socket code?
If you can re-use the efforts of others, MQTT seems like a good fit for your requirement.
jahboater
Fri May 22, 2020 7:13 pm
Pi-Pi should be the same. The Pi wont know the difference been another Pi and a PC.
The basic documentation for Linux sockets is actually pre-installed with Raspbian.
Just type "man socket" to start ...
Pi4 8GB running PIOS64
knute
Fri May 22, 2020 9:30 pm
Hi all,
Are you talking messages as in data acq/dist or text messages for humans?
