New Pi 4 Camera Ribbon
Posted: Fri May 22, 2020 2:40 am
by vidrazor
Hi folks, I'm rigging up a Pi4/Pi Camera duo to use in astrophotography, and I'm planning on bolting the camera right to the top of the Pi 4 case and using it as a guide cam in addition to other astro duties in one contained package.
So my question is really about the connecting ribbon from the camera to the Pi 4. Is it possible to cut a short piece of it and still use it? If not, where could I order a shorter ribbon with the same connections? I'm only going to need about 3-4 inches max within the case.
Thanks for any info on this.
Re: New Pi 4 Camera Ribbon
Posted: Fri May 22, 2020 4:31 pm
by wildfire
Google is your friend...
https://www.amazon.com/Flex-Cable-Raspb ... B00I6LH2GA (10cm so around 4 inches).
Posted: Fri May 22, 2020 4:34 pm
by W. H. Heydt
No. As above, cables in various lengths are readily available commercially. When you examine a cable, you should be able to see why just cutting it to a convenient length won't work.
Posted: Sun May 24, 2020 1:21 am
by vidrazor
OK guys thanks for the info. I'm raw to all this, so I wasn't sure how pliable the tech is.
Thanks again.
