Kevin_JD
Google Maps On Chromium :D
Sun May 17, 2020 4:32 pm
:lol: Have anyone tried to open Google Maps On Chromium ??? Hole Earth is upside down :D And Its On Every browser !!! Except Vivaldi :lol: Seriously how can i fix this ???
2020-05-17 1scrot.jpg (58.85 KiB) Viewed 2009 times
Botspot
Re: Google Maps On Chromium :D
Mon May 18, 2020 2:46 pm
While I've not been able to reproduce this bug, it appears to be related to the Fake KMS driver.
See these other topics:
viewtopic.php?f=28&t=270113
viewtopic.php?f=28&t=269138
Want to run Minecraft Java on your RPi? Easiest way is with Pi-Apps - just click Install.
https://github.com/Botspot/pi-apps
Pi-Apps also includes Zoom, Visual Studio, Tor browser, Windows 10 theme, and 33 more.
Over 50,000 users!
Wed May 27, 2020 9:20 am
Can anyone seeing this try setting the environment variable before running Chromium from a terminal
MESA_EXTENSION_OVERRIDE=-GL_MESA_framebuffer_flip_y
And see if it helps?
hippy
Wed May 27, 2020 11:57 am
Fixed the problem for me with Google Streetview. Pi 3B (non-plus)
Google Maps was fine for me without even though Streetview wasn't.
Maybe members could post a few links to problem sites so others can test with and without ?
HudsonMoore
Wed May 27, 2020 6:30 pm
Yes, fixed the problem for me too.
I originally reported (in this thread) problems with Google Maps, the Johns Hopkins Coronavirus map, and a map on the New York Times website and all three are correct now.
Thanks, jamesh!
RPi 4B Buster
Wed May 27, 2020 10:57 pm
Thanks, jamesh!
Igalia our contractors who deal with MESA figured it out. Smart guys.
ndg2000
Sat May 30, 2020 7:27 am
Can anyone explain how I change that variable please in a noob at Linux
hippy
Sat May 30, 2020 7:51 am
From a Terminal / Command Line Interface opened from the desktop ...
MESA_EXTENSION_OVERRIDE=-GL_MESA_framebuffer_flip_y chromium-browser
ashburn15
Thu Sep 24, 2020 7:19 pm
Is there a way to make the settings "stick" instead of having to use it in the terminal every time before using Chromium? This setting fixes inverted games for the kids and I'm a newbie myself (RPi 3B+)..
For now, i've created a Desktop Shortcut calling the "mesa extension override.." command thru lx terminal. Not pretty but works. A "corrected" Chromium starts up after a few secs while lx terminal window is running in the background.
Botspot
Fri Sep 25, 2020 3:06 pm
As I have never personally encountered this problem, I cannot test the below solution, but you let me know if it works. In a terminal:
export MESA_EXTENSION_OVERRIDE=-GL_MESA_framebuffer_flip_y
Now, from the Menu, launch Chromium. Let me know if that worked.
Over 50,000 users!
ashburn15
Fri Oct 02, 2020 12:45 pm
Doesn't work. No errors or anything in Terminal for the "export.." but still inverted when launched from Menu (Pi>Internet>Chromium) even after reboot..
Botspot
Fri Oct 02, 2020 12:54 pm
Then change the default Chromium menu button's command to include this at the beginning:
Over 50,000 users!
ashburn15
Fri Oct 02, 2020 3:57 pm
I'm sorry but what would be entire line under "command" for the Desktop Entry (or "Exec=" if using text editor)? Things like
MESA_EXTENSION_OVERRIDE=-GL_MESA_framebuffer_flip_y chromium-browser %U
or
chromium-browser - -'MESA_EXTENSION_OVERRIDE=-GL_MESA_framebuffer_flip_y'
or similar don't work directly on the GUI Desktop Entry.
lxterminal -t "Loading Chromium for Games.." -e 'MESA_EXTENSION_OVERRIDE=-GL_MESA_framebuffer_flip_y chromium-browser'
works (as a desktop shortcut) but its a lxterminal shortcut and not a direct Chromium menu shortcut (if 1 exists at all).
Sorry i'm a newbie :roll:
Botspot
Fri Oct 02, 2020 4:08 pm
or
I should have been more clear. Yes, put the chromium-browser after the MESA_GL stuff.
If you say that doesn't work, then try snclosing the whole thing in bash -c.
So your full Exec= line would look like:
bash -c 'MESA_EXTENSION_OVERRIDE=-GL_MESA_framebuffer_flip_y chromium-browser'
Let me know if that works.
Over 50,000 users!
ashburn15
Fri Oct 02, 2020 4:52 pm
Thank You! Yes. This finally works! Can be used for editing the Chromium shortcuts in Menu and Desktop.
Now looking for the way to edit the Application Launch Bar (LXpanel?) on the bottom left and it will be complete. Thank you again!
Botspot
Fri Oct 02, 2020 4:56 pm
Thank You! Yes. This finally works! Can be used for editing the Chromium shortcuts (Menu and Desktop) under "Command" or "Exec".
Good to know.
The Application Launch bar stores its own .desktop files in a separate location. To make it use the new .desktop file, first remove Chromium from Application Launch Bar's list, then add it back again.
Over 50,000 users!
ashburn15
Fri Oct 02, 2020 5:08 pm
Good to know.
That's a great tip! Just remove the "Browser" option in the Application Launch Bar Settings and add "Chromium" from your Internet List. Now all the Chromium shortcuts reference the inverted/upside down fix correctly. Thank you once again!
blankNick
Wed Oct 21, 2020 7:10 am
How to override chromium start .sh file to include this option that it would start everytime? I'm running only chromium browser. Tried before chromium-browser command to include MESA_EXTENSION_OVERRIDE=-GL_MESA_framebuffer_flip_y, but nothing changed. Also tried in flag line as flag like this --MESA_EXTENSION_OVERRIDE=-GL_MESA_framebuffer_flip_y also nothing. How to make it always flip chromium on start? Thanks for help I'm noob on linux too...
Botspot
Wed Oct 21, 2020 1:02 pm
First, we have to understand that this variable (MESA_EXTENSION_OVERRIDE) is a bash environment variable that chromium is programmed to obey.
To automatically set environment variables on boot, just add this line to your /home/pi/.bashrc file:
Over 50,000 users!
ShiftPlusOne
Tue Nov 17, 2020 6:44 pm
I'm trying to figure out if that parameter is something we should add to the launcher script by default, but am unable to reproduce the issue.
Could somebody who experiences this issue please post their 'chrome://gpu' page?
ShiftPlusOne
Tue Nov 17, 2020 7:00 pm
Okay, I managed to find an old email detailing the issue and reproduce it with v78. It seems to be fixed in v84.
