RetroPie on SD
Posted: Sun May 17, 2020 10:36 am
Guys hi.
In Raspian on my Pi4 I tried the https://retropie.org.uk/docs/Manual-Installation/ instructions and I get only some packages to work: most of the ROM are not working... they never pass the runcommand..
Is this a stable installation?
Do I need to anything particular for the ROM to work?
Anyway: I can see that the recommend way is to install Retropie on the SD card: do i need to install the image on a different SD card? Can I add the image to the SD from where Raspian is booting?
I cannot see the SD card from the terminal: it seems all the space is in /boot?
If I'm going to use Etcher on the SD where I have the Rapsian on, I am going to overwrite it?
Thanks for your patience,
Gabriele
Gabriele
