Understanding the pi 5V pins
Posted: Fri May 15, 2020 10:49 am
Hey, I'm not that familiar with the power side of things so just wanted to check if my understanding is okay here before jumping in...
I currently have a Pi4 in a 3D printed enclosure along with a powered USB3 hub (with 2 HDDs connected). Everything is running fine from a power point of view given the hard drives are running off their own power source and the Pi off a suitable source itself but I'm now looking to add a little extra cooling to the enclosure.
I currently have a fan shim attached to the pi (which is rarely triggered) but I'm hoping to add two small 30mm 5v fans to either side of the rear of the case. Is it okay to power all 3 of these fans from the Pis 5V pins? I've connected one to the 5V and GND pins above the fanshim and it appears to be okay, just wondering would it be okay to add the third fan off the remaining two 5V and GND pins?
The shim uses ?A and the small fans use 0.18A each so around 0.54 A overall between them if all running at once (which is less than an unpowered HDD would use off the usb port which generally seems to be okay).
Thanks!
Thanks!
