frantal
Old Raspberries...
Thu May 14, 2020 7:56 am
I have 2 Raspberry B ver.2.0 (512MB RAM) I tried to install Raspbian (Buster) and Kali, but they are so slow that it is impossible to use them. What do you suggest to continue to use these 2 Raspberries? Any suggestion of which software could I install to let them still in life? Thanks for the suggestions!
Re: Old Raspberries...
Thu May 14, 2020 8:12 am
Whatever project can be run from the command line would probably be fine. Get rid the desktop completely. Saves a load of memory and CPU cycles. Using the legacy graphics driver would also makes things a bit quicker - the newer DRM/MESA drivers requires 1GB RAM.
Thu May 14, 2020 8:31 am
Ouch! How did that happen?
TinyCoreLinux:
http://forum.tinycorelinux.net/index.ph ... ,57.0.html
Raspbian Buster Lite with Minimal Kiosk Browser as a front end:
viewtopic.php?t=40860
LibreElec if need a Multimedia Operating System:
https://libreelec.tv/about/
Retropie if need a retro gaming Operating System:
https://retropie.org.uk/
Thinking outside the box is better than burying your head in the sand...
mikerr
Thu May 14, 2020 9:06 am
Plenty of use left in them, mainly for non desktop duties.
As headless servers, or media players.
Remember pi zero is effectively same spec as pi 1 in terms of ram and cpu.
AcmeUK
Thu May 14, 2020 9:44 am
I have an old model B.
It runs DietPi_v150_RPi-armv6-(Jessie) quite happily.
Thu May 14, 2020 10:49 am
Perhaps requires is the wrong word. How about doesn't work very well with less than 1GB RAM?
As for why? It's all upstream code, best ask them.
drgeoff
Thu May 14, 2020 12:02 pm
Zeros have twice the RAM of the first Model Bs.
LTolledo
Thu May 14, 2020 12:44 pm
same as this one?
(in old DIY case)
RPi1B DAC HAT in new DIY case open.jpg (197.48 KiB) Viewed 1030 times
(this is the updated DIY case)
used it as Kodi Media Player... for watching videos (up to 5.1ch encoded 1080p videos)
controlled via old smartphone Kodi app (Kore)
Some people be like:
DirkS
Thu May 14, 2020 12:47 pm
But then OP has already stated he has the 512MB model
mooblie
Thu May 14, 2020 1:40 pm
Would Pihole work? Worth investigating:
https://pi-hole.net/
scruss
Thu May 14, 2020 2:04 pm
same as this one?
That's got mounting holes. The very first ones didn't. Not that that would make 'em faster — unless you were throwing them, I suppose.
Pronouns: he/him
DarkElvenAngel
Thu May 14, 2020 2:33 pm
I have pi hole, pivpn running on a B+ same idea as a B just more GPIO and usb ports
Idahowalker
Thu May 14, 2020 2:55 pm
I have a RPi3b that I let run as a community service by running a few BOINC https://boinc.berkeley.edu/ thingies.
Idaho, U.S.A.
hippy
Fri May 15, 2020 11:57 am
But hardly relevant for someone asking about what to do with their original model Pi's.
boyoh
Tue May 19, 2020 3:11 pm
Plenty of life in the Old Pi , If you use it as it was intended to do That was to learn Coding and Electronics.
Why buy a more powerful modal, when you have not mastered the first one, Why buy something then stick it in
a fancy box with a couple fans ,and not knowing how to use it . They read up what the Pi can do, then that is as fare
thy get, They learn coding in a few weeks , then they think , that is all thy need to Know,, In time there will be more
Coders than Electronic Engineers
My advice is get the bread board out and learn ,some basic electronics , It is far more fun to see your project work
There are a lot of good men on the forum who give you good advice , and point you in the right direction.
Regards BoyOh Retired Electrical / Electronic Technician
BoyOh ( Selby, North Yorkshire.UK)
Some Times Right Some Times Wrong
