fostes
Raspberry pi 4 mobile charger
Sat May 02, 2020 6:46 am
Can i use mobile charger for Raspberry pi 4?
I have this:
LTolledo
Re: Raspberry pi 4 mobile charger
Sat May 02, 2020 8:46 am
try if you must
may fail if you insist
suggestion is to desist
official RPF PSU you should trust.
Some people be like:
Sat May 02, 2020 2:39 pm
Most likely not. The RPi needs a stable 5.1V 3A power supply, not a charger.
fostes
Wed May 06, 2020 7:41 pm
In my country i dont find official charger for PI 4, so i must find alternatives.
drgeoff
Wed May 06, 2020 8:39 pm
There is no official charger. RPis have nothing whch needs charging. RPis need a good power supply. Some chargers do not pass muster.
FTrevorGowen
Wed May 06, 2020 8:46 pm
In what country are you based (you don't indicate where in your user profile)?
Trev.
W. H. Heydt
Wed May 06, 2020 9:37 pm
Side note...given what is printed on the device in question, that is "PD Rated". As such, whether or not it has even the slightest chance of working with a Pi4B will depend on which version of Pi4B you have, v1.1 or v1.2. (Problems for PD PSUs was addressed in the board version change to v1.2.)
jbudd
Wed May 06, 2020 11:11 pm
Doesn't that depend on the cable too? So long as it is not a PD cable it ought to work equally well/badly on both versions of the Pi4B
Imperf3kt
Thu May 07, 2020 12:05 am
In this case it depends entirely on the cable as it will default to 5v 3A output in the event you use an unsupported device or non-smart cable.
55:55:44:44:4C
52:4C:52:42:41
fostes
Thu May 07, 2020 11:42 am
I am from Montenegro.
The best supply i can find for now is 5V3A with 1M cable.
FTrevorGowen
Thu May 07, 2020 2:18 pm
You may be O.K. with that cable length (depending upon what you intend to use in the USB ports). FWIW, I measured better loading behaviour for this Tronsmart device: https://www.cpmspectrepi.uk/raspberry_p ... .2FCharger
when I changed from the 1.8m cable supplied to a 0.9m one. That still powers one of my P4B's but, apart from a keyboard & mouse, I mainly use USB3 (or USB2) flash drives (32Gb/64Gb) and/or a USB3 card reader (the latter when cloning the uSDHC card**)
Trev.
** https://www.cpmspectrepi.uk/raspberry_p ... OnP4B.html
(Again, FWIW, some other USB device "PoWeR" requirement notes are here:
https://www.cpmspectrepi.uk/raspberry_p ... rives.html
https://www.cpmspectrepi.uk/raspberry_p ... aders.html )
Trev.
