elserba
Change resolution?
Wed Apr 29, 2020 9:11 pm
Hello everyone! I have tried my best to investigate and be able to solve this problem, but have been unable. I have a Raspberry Pi 4 B (4gb ram) with Batocera 5.25, the problem is that my TV is 4K and the games are not working "fluently". I am sure that if I can change the resolution to 1080 (full HD) or 720p everything would be better. I don't know how to exit the interface to access the Linux configuration, or how to modify the resolution.
I thank you in advance for any help!
A greeting!
kerry_s
Re: Change resolution?
Wed Apr 29, 2020 10:33 pm
i'm thinking either try "ctrl+alt+t" see if it brings up a terminal
otherwise you can try the tty's "ctrl+alt+any f1->f7 key"
if you can get a console you can just nano the /boot/config.txt with your settings.
elserba
Thu Apr 30, 2020 5:30 am
Thanks friend for your answer, although that has not worked, even with ctrl + alt and all the keys nothing happened.
Other idea?
Thank you!
kerry_s
Thu Apr 30, 2020 5:53 am
okay, according to this page-> https://wiki.batocera.org/doku.php?id=display_issues
you press f1 & then f4
elserba
Thu Apr 30, 2020 1:06 pm
brilliant! I have seen the tutorial, what happens is that I connect from Windows, I do not have Linux to be able to open a terminal and configure Batocera remotely. I have another option? editing some configuration file for example?
