Bruce_Pi
compute module does not show up
Fri Apr 24, 2020 9:00 pm
HI,
I am trying to flash OS in the CM module.it has 16GB flash.
I installed the RPI boot utility. it seems to work fine but the module does not show up as a USB drive as it should.
I tried 2 modules so far. both doing same.
Yes, the J4 is installed correctly.
I see a tons of other people are having the same issue but no solution. was wondering if someone has any idea how this can be fixed.
