How to connect with RPI from other network?
Posted: Thu Apr 23, 2020 4:55 pm
by Zordey
Hello!
The RPI is setup on my local network and everything is working. How I can connect with device using smartfon and VNC?
Re: How to connect with RPI from other network?
Posted: Thu Apr 23, 2020 6:20 pm
by drgeoff
Zordey wrote: ↑Thu Apr 23, 2020 4:55 pm
Hello!
Can the phone connect by Wi-Fi to the same network the RPi is on? Or must the phone use the cellular network?
Posted: Thu Apr 23, 2020 6:21 pm
by B.Goode
Welcome to the Raspberry Pi forums.
Hello!
The Raspberry Pi organisation has documentation for most common uses of their products.
In this case -
https://www.raspberrypi.org/documentati ... /README.md
Posted: Thu Apr 23, 2020 6:49 pm
by Zordey
drgeoff wrote: ↑Thu Apr 23, 2020 6:20 pm
Hello!
No Wi-Fi only cellular network
Posted: Thu Apr 23, 2020 7:44 pm
by drgeoff
Zordey wrote: ↑Thu Apr 23, 2020 6:49 pm
Hello!
Either:
1. You will need to know the public address of the NAT router between the internet and the network the RPi is on. You will need to forward port(s) on that router. None of it is RPi specific.
or
2. Use the "cloud" method as per the instructions on the page linked to by B.Goode.
Posted: Sun Apr 26, 2020 7:40 pm
by Zordey
I used NO-IP but its a little exepnsive method.
