What would you advise me to do ? Can a pi zero wh run a programm on startup involving a sim900a module and a 16 channel relay ? Or should I use a 3B+ because the pi zero wh isn't powerful enough ?
Depends on what else your zero has to do?Goldhelmeth wrote: Hello,
The Zero can handle that, but what are you doing with the data once you have it? That could be the bottleneck.Goldhelmeth wrote: ↑Fri Apr 17, 2020 4:00 pmHello,
Goldhelmeth wrote: ↑Fri Apr 17, 2020 5:24 pmThanks for your answers,
The programm wil await a received message from the sim900a module or a message from another pi zero that is connected via ethernet. Upon receiving this message and in function of the content it will for example switch on a specific channel of a relay or ask the second pi to send him data in order to send it via the sim900a module.
Also it will await for a specific wifi network to be inbound and it will connect to it...
[/quote
From BoyOh
I will give you credit were it is due , You are very good at writing about it ..You are very good at talking about it
You are very good at thinking about ....This is were the credit comes in You Know moor about the Pen Than you know about the Screw Driver.
Regards BoyOh
