sibir
How to disable caps-lock
Mon Apr 13, 2020 5:05 pm
Looking for a quick how-to I was surprised not to find anything (easily) here.
So if you want to permanently disable the caps-lock key on the keyboard for the user "pi" and you are running Buster, add this line
@setxkbmap -option caps:none
to your /etc/xdg/lxsession/LXDE-pi/autostart
You need root-access to write to that file, so you could use
sudo nano /etc/xdg/lxsession/LXDE-pi/autostart
If you are on an older (pre-Buster) release the /lxsession folder is in /home/pi/.config/
If you use a different username go to the corresponding folder in /etc/xdg/lxsession/
Botspot
Re: How to disable caps-lock
Mon Apr 27, 2020 12:22 am
"Looking for a quick how-to..." Did you happen to find this one? AFAIK it's permanent. ;)
Want to make your own Raspbian image?
  • Hard way: Mess with confusing terminal commands.
  • Easy way: Let Pi-Power-Tools do it all for you!
Boot your image in a VM, Flash from the Internet at top speed, Mount (to drop files in), Edit partitions, Shrink/Expand, Repair, and more. Enjoy! :)
https://github.com/Botspot/Pi-Power-Tools
