I'm trying to setup my Raspbi with Raspbian, LibreELEC and Lakka. Since it is placed in my Living-Room, I don't have Keyboard & Mouse connected and am using it via VNC.
So, in order to change the distribution, I would have to reboot it via VNC and select the distribution at that time, because I don't have control in NOOBS.
I found this solution ( viewtopic.php?t=71107 ), which seems to be outdated.
Then I found this one ( viewtopic.php?t=196094 ) using
sudo reboot [partition],
but that doesnt't work. LibreElec is located on partition 8 ( which I found out that way https://www.instructables.com/id/Contro ... -/#discuss ), but whatever number I enter after reboot, the raspberry always boots into Raspbian. The solution posted there doesn't help, because I don't want to change the default boot-partition, but only want to be able to start LibreELEC out of raspbian.
systemctl reboot [partition]
as mentioned here (viewtopic.php?f=91&t=266092&p=1617010&h ... n#p1617010) doesn't work either; I guess it's the same command anyway?
What am I doing wrong here? I'm totally new to this and don't have any idea at the moment. :-/
Thanks i advance,
Best regards.
