superidiot123
Bad soldering
Sun Apr 05, 2020 3:28 pm
Hello everyone,
I'm new into soldering electronics and I've probably broken my RPi Zero W unfortunately. I've checked the voltage on all pins and next to 3.3V I have also 3.3V and I'm not sure if it is correct? This is the pinout for the board.
My friend has re-soldered the pins but still I have 3.3V next to "blue" pin.
B.Goode
Re: Bad soldering
Sun Apr 05, 2020 5:20 pm
welcome to the Raspberry Pi forums.
Hello everyone,
That display is just static information. It doesn't measure anything.
It corresponds with this web version of the same information.
https://pinout.xyz/
Physical pins #1 and #17 on the header should provide 3.3 volts.
Burngate
Re: Bad soldering
Sun Apr 05, 2020 5:30 pm
... but still I have 3.3V next to "blue" pin.
Do you mean the pin labeled "GPIO2" on your diagram? If so, that may not actually a problem -it could just be normal.
GPIO2 (and the next one, GPIO3) are used to talk to I2C devices; they have a resistor pulling them up to 3v3, so when they're not doing anything else, that's what a meter would read.
Of course I don't know how bad your soldering actually is, nor how good your friend's is, so I can't declare everything hunky-dory. But I'll keep my fingers crossed.
neilgl
Re: Bad soldering
Sun Apr 05, 2020 7:02 pm
And to check the status of a given GPIO (e.g. 21) start a terminal and enter this:
raspi-gpio get 21
that should show
GPIO 21: level=0 fsel=0 func=INPUT pull=DOWN
Meaning it is at level 0 i.e. 0 volts, not 3.3 volts.
Good luck with soldering that header onto the pi zero W.
