lse123
Raspberry Pi Imager, how can install 3 or 4 OSs including Raspbian OS
Sat Apr 04, 2020 4:14 pm
Raspberry Pi Imager
After download for windows 10 - Raspberry Pi Imager, how can install 3 or 4 OSs including Raspbian OS... in the SAME micro sd card? Can you use a 64GB micro sd card for this?
you have a video on YouTube about installing more than one OS using Raspberry Pi Imager?
I can install even 10 OSs on the same micro sd card if having space?
B.Goode
Re: Raspberry Pi Imager, how can install 3 or 4 OSs including Raspbian OS
Sat Apr 04, 2020 4:27 pm
Raspberry Pi Imager
I believe the intended purpose of the relatively new Raspberry Pi Imager tool is to install a single Operating System image onto a microSD card.
Maybe see PINN, a user-supported tool which has its own lengthy thread in these forums.
Sat Apr 04, 2020 4:53 pm
The Imager program will normally only install one OS on a card.
But you can use it to install PINN which allows you to install more than one OS
Unreadable squiggle
Sat Apr 04, 2020 4:55 pm
+1 PiNN
https://www.raspberrypi.org/forums/view ... 3&t=142574
Thinking outside the box is better than burying your head in the sand...
procount
Mon Apr 06, 2020 10:00 am
You can use the Raspberry Pi Imager tool to install PINN (see https://www.raspberrypi.org/forums/view ... 8#p1638508)
