Thu Apr 02, 2020 6:48 pm
cerbrus2 wrote: ↑Thu Apr 02, 2020 6:00 pm
Hi peeps.
I got my Kid a Pi4. when it turned up in the post, we put it in its case, hooked up the cooling fan that came with the case. Put the Raspbian OS on an SD card via the the Raspberry Imager. Inserted the SD car. connected it up to the TV via a Mini HDMI - HDMI converter.
We are only getting a Red LED, and no signal. I downloaded the recovery bootloader, and put that on a SD card, Inserted it into the pi, and plugged in the power. We are supposed to get a flashing green light, but still just a solid red light.
I have tried multiple powersupplies, Direct 2.4amp wall socket, an Amazon Fire power brick, My Old razer phone powerbrick. And then we tried the Nintendo Switch Light powerspply, that should be more than enough power for it. but none make any difference.
Any idea?
Is the Pi we got sent a dud?
1) You don't mention any form of "official" power supply. Did you not purchase one with the P4B? (With others, whilst some may work, depending upon the quality/type of connecting lead YMMV.**)
2) Have you tried without having the fan connected? (None of my P4B's have one in use including the one I'm posting from.)
3) What happens if you power up without any uSDHC card present (as well as no fan)? IE. do you get the repeated four green ACTivity led flash pattern?
NB.If the red PoWeR led flashes/dims at any time that's a definite indication of "bad" power.
** The only, "generic" USB C power supply + USB C-to-C lead combo. I know of personally that works is this one (acquired before official PSU's became generally available):
https://www.cpmspectrepi.uk/raspberry_p ... .2FCharger .
Trev.
