unable to get any OS on my new RaspberryPi 4B
Posted: Wed Apr 01, 2020 5:09 pm
by telebube
Hi there,
I got a brand new RaspberryPi 4 to install a nextcloud server for home.
I tried all the following:
1. put the nextcloudPi image to my SD-Card and started my RaspberryPi
---> no HDMI signal input
2. installing Raspian with Noobs
---> stuck in rainbow startscreen
3. to install Raspian using a SD-card prepared with Raspberry Pi Imager
---> System did not start
4. installing the new bootloader to the Raspberry
5. tried to install Raspian
---> stuck in an automatic login loop (timeout after 60 sec)
6. tried to install Ubuntu using a SD-card prepared with Raspberry Pi Imager
---> stuck with cloud-init.....
Can anybody give me a helping hand? I've no idea what to do any more...
I'm using the original power supply cable and the oroginal HDMI adapter and an Intenso microSD with 32G
Thank you!
Re: unable to get any OS on my new RaspberryPi 4B
Posted: Wed Apr 01, 2020 5:35 pm
by B.Goode
Welcome to the Raspberry Pi forums.
Hi there,
Thank you!
The common factor in everthing you have tried seems to be the microSD card, and/or the writer device used to prepare it.
Maybe one or both of those is faulty?
Posted: Wed Apr 01, 2020 6:16 pm
by telebube
Ok, thank you, then I probably need another SD card, are there any recommended?
Posted: Wed Apr 01, 2020 6:20 pm
by dustnbone
I tend to stick to the bigger names when it comes to memory cards. Kingston, Sandisk, Patriot, Samsung, etc.
I haven't tried an off brand uSD in many years, maybe they're not so bad now but back in the day they were a nightmare.
Posted: Wed Apr 01, 2020 6:24 pm
by procount
Are you using an external USB card reader to flash your SD cards? They are preferred.
Some internal laptop SD card readers are not good at writing the larger SD cards >=32GB
Posted: Wed Apr 01, 2020 6:27 pm
by telebube
Ok, thanks, I ordered a Samsung...
We'll see what happens ;-)
by Botspot
They can still be a nightmare now. Everything from "My Pi keeps having kernel panics and corruption", to "My Pi doesn't remember anything after a reboot", to "It took over 10 minutes to open a terminal". :lol:
Posted: Fri Apr 03, 2020 5:19 pm
by telebube
Bought a Samsung EVOPlus 32GB, NOOBS didn't work but RASPIAN via Raspberry Pi Imager
:P
Thank you
