Sun Mar 29, 2020 2:35 pm
GTB-JJ wrote: ↑Sun Mar 29, 2020 2:19 pm
I've assembled a Raspberry Pi for the first time , and turned the power on. The power cord came out came before the Raspberry Pi completed whatever housekeeping newly assembled Pi''s do when they are turned on
When I connect the power lead now, just the red power light comes on. The Pi doesn't do anything. What do I do to get the Pi to complete it's housekeeping?
Thanks for any help.
I'm guessing you have a kit that came with a uSDHC card with NOOBS pre-installed. Is that the case? If so it's quite likely that the accidental power removal left the card in a "corrupted" state. Do you have access to another computer with a suitable card slot or a USB-base card reader writer? If so I suggest you write a fresh "Raspbian image" using the new imaging tool:
https://www.raspberrypi.org/downloads/ and try again without powering up (at the mains AC socket) before all other connections (USB, HDMI etc.) have been checked to be "secure". It's also a good idea to have the display/TV switched on and the correct input selected first.
Trev.
