So my RPi Zero is running on a normal iphone socket in my wall at about a constant 100% cpu usage with about 0.08 - 0.10 mbps (out).
What do you reckon the monthly cost of this would be?
ThatDevAaron wrote: ↑Sat Mar 28, 2020 8:31 pmSo my RPi Zero is running on a normal iphone socket in my wall at about a constant 100% cpu usage with about 0.08 - 0.10 mbps (out).
Not really. What is the GBP/KWH rate?
Last time I did a bit of rough paper maths I got a rough number of about GBP£5/year. The Raspberry does more for fewer watt hours with the 4B, so still £5/year.
No problem with the answer to your post Switch all off in your house , Just leave the Pi powered up ,go on holidayThatDevAaron wrote: ↑Sat Mar 28, 2020 8:31 pmSo my RPi Zero is running on a normal iphone socket in my wall at about a constant 100% cpu usage with about 0.08 - 0.10 mbps (out).
Don't forget to subtract the standing charge to leave only the cost of the electricity used by the Zero.boyoh wrote: ↑Sat Mar 28, 2020 11:44 pmNo problem with the answer to your post Switch all off in your house , Just leave the Pi powered up ,go on holidayThatDevAaron wrote: ↑Sat Mar 28, 2020 8:31 pmSo my RPi Zero is running on a normal iphone socket in my wall at about a constant 100% cpu usage with about 0.08 - 0.10 mbps (out).
for three months , then check your electricity bill when you, get it, then you will know the cost
Regards Boyoh
Forgot to carry the 1
Getting a Pi0 to draw 1A would take some doing. What would you have connected to it? Personal experience is that a Pi0 with an attached 3.5" LCD panel draws a bit under 200mA, or just under 1W.
