RobHenry wrote: If you are really stuck then you can connect temporarily by ethernet and download an add-on that will detect your ssid and step you through the configuration. Similarly you can connect to the device via ssh when it is wired into your router.
Rob,
What add-on (to detect my ssid and step me through the configuration) would you suggest?
I've tried everything at the link for Wireless 101, and my Raspberry Pi still does not seem to be requesting an IP address from my DHCP-enabled router, EXCEPT when connected by wire.
Yes, I can log in with SSH when connected by wire.
The system I will later need to log into is at our library and, while I have all the relevant netmask, gateway, SSID, and DNS settings (there is no security being used at the library), I do not have access to their router and do not have a static IP address and the OpenElec, even when configured correctly with all the wlan0 info, still is not given any IP address by the library's wi-fi router.
Same thing happens at home when reconfigured for wi-fi on my home network.
Could this be what's happening:
http://openelec.tv/forum/69-network/606 ... spberry-pi
I would feel MUCH more confident about wi-fi in OpenElec if the settings menu allowed me to choose between "Static IP Address" and "Use DHCP" by actually saying so someplace. As of Feb 17 2013, I see no settings in OpenElec (the add-on) under Network that indicate where I could tell it to use DHCP to acquire an IP address from the router. Obviously it (DHCP) works when wired, but our local library has disabled practically all their wired Ethernet jacks except the ones in use by their own computers.
The add-on to detect the wireless SSID and step me through the configuration would be tremendously helpful. What's its name and where can I get a version of it to run on the Raspberry Pi's Arm V6 processor under OpenElec?
