Raspberry Pi Imager and Raspberry Pi 3B
Posted: Fri Mar 13, 2020 1:37 am
by shane256
I have a Raspberry Pi 3B. The 4 is out as well as the other models. When I'm in the Raspberry Pi Imager, I can make a Raspbian image but it doesn't say specifically which models that image supports. Do Raspbian images support all the models of Raspberry Pi? For example, if I made an image, could I take use it on the 3B and a 4 as well?
Re: Raspberry Pi Imager and Raspberry Pi 3B
Posted: Fri Mar 13, 2020 7:00 am
by rpdom
shane256 wrote: ↑Fri Mar 13, 2020 1:37 am
Yes. Currently, at least. There is a possibility that a separate image may appear at some stage that will only work on the later models of Pi that have 64-bit capable CPUs. But there will still be an image that works on the Pi 0-4 in 32-bit mode for quite a few years to come.
Posted: Fri Mar 13, 2020 10:22 am
by FTrevorGowen
rpdom wrote: ↑Fri Mar 13, 2020 7:00 am
+1 but adding the reminder that
older images will probably not work on
newer Pi's since such (future) Pi's are likely to need firmware that the old image doesn't have.
Trev.
Posted: Fri Mar 13, 2020 10:26 am
by alphanumeric
There is a table here that will tell you what runs on what Pi.
https://en.wikipedia.org/wiki/Raspbian
Posted: Fri Mar 13, 2020 10:37 am
by B.Goode
A useful form of presentation. But it is a Wikipedia page with no assurance of accuracy.
I would prefer to trust the Raspbian Release Notes published by Raspberry Pi themselves -
http://downloads.raspberrypi.org/raspbi ... _notes.txt
I can see at least one place where the information differs. (I don't feel motivated enough to learn to be a Wikipedia editor.)
Posted: Fri Mar 13, 2020 12:24 pm
by shane256
Thanks all... exactly what I needed to know.
