Rcayot
Pi Zero W which OS?
Fri Mar 06, 2020 5:36 pm
I recently purchased a Pi Zero W, and set it up with a full blown raspbian install. I think this was a mistake as it is dreadfully slow.
Upon running setup again, which version should I choose. I REALLY don't want just the shell for an interface.
Thanks,
Roger
Re: Pi Zero W which OS?
Fri Mar 06, 2020 7:11 pm
It IS slow and changing the base OS won't make a jot of difference (it's slightly overclocked from the original RPi1B) but it's still only one BCM2835 core with 512MB. If you want fast get a RPi4B.
One thing that makes it very slow is swapping to SDCard. You really do not want to do that, so don't over commit RAM with bloatware (like web browsers).
https://magpi.raspberrypi.org/articles/ ... benchmarks
Rcayot
Fri Mar 06, 2020 7:22 pm
I see. Is there a performance benefit to installing Buster with desktop and no software?
I am having a bit of trouble finding out info on the NOOBS options.
Thanks,
Roger
B.Goode
Fri Mar 06, 2020 7:40 pm
Thanks,
Roger
NOOBS is simply an Installer. It doesn't have any options that will have any bearing on the performance of your bottom-of-the-range RPiZero board.
Your decision is about which of the 3 variants of the Raspbian Buster Operating System to install. https://www.raspberrypi.org/downloads/raspbian/
If you want a GUI Desktop then you don't want Lite.
If you want a GUI Desktop but no useful pre-installed software to run, then choose 'Buster with desktop'
But if you want the out-of-the-box, ready to run, 'batteries included' experience, choose 'Raspbian Buster with desktop and recommended software'
Simple.
That deals with the Raspberry Pi recommended and supported Raspbian Operating System. Other third-party, less well supported, options are also available.
Fri Mar 06, 2020 10:02 pm
Thanks,
Roger
An alternative, though not as fully featured, is Tiny Core Linux with Desktop:
https://iotbyhvm.ooo/picore-tiny-core-l ... pberry-pi/
My other Linux machines are a ChromeBox & Intel CoreDuo Desktop
Return to “Beginners”
