mikerr
Re: "Introducing Raspberry Pi Imager, our new imaging utility"
Fri Mar 06, 2020 1:28 pm
Apparently Windows 10 Smartscreen will stop blocking it after a few thousand installs (or so RPi hopes ! )
B.Goode
Fri Mar 06, 2020 1:29 pm
Not entirely fair or accurate, but I can't stop my mind wandering to the situation caricatured here -
https://xkcd.com/927/
(But a Raspberry Pi provided and supported tool to write a Raspberry Pi operating system image for a Raspberry Pi board seems to be a sensible contribution to the toolset available. There is no compulsion to use it.)
fbe
Fri Mar 06, 2020 6:53 pm
Couldn't imager also be used to write Debian with Raspberry Pi Desktop images to an USB drive?
Fri Mar 06, 2020 10:04 pm
They are .ISO not .IMG format :?
emma1997
Fri Mar 06, 2020 11:48 pm
Quick warning for those considering install under XP. It loads, taking significant chunk of disk, then fails with error message about missing 'CancelioEx in DLL'.
PS Edited to reflect incompatibility with the outdated OS only. My error was not taking proper steps in control panel to remove it. After running on a 'modern' win10 netbook I see it's not as big as some of huge packages on there. Unfortunately my XP mobos are the only ones with serial/parallel and run XP/98.
ShiftPlusOne
Fri Mar 06, 2020 11:59 pm
You should be able to uninstall it from Add/Remove Programs in the Control Panel, but if you're running XP, you have bigger problems than that.
https://support.microsoft.com/en-gb/hel ... of-support
emma1997
Sat Mar 07, 2020 1:07 am
Thank you. It didn't reclaim everything but almost. Missed it first time through. Hundreds of entries just under 'r' alone, I was looking under 'i' for some misguided reason.
One man's problems are another man's solutions. I do have a Win8 and several Win10 but despise that whole bunch which is one reason I'm trying to replace with Pi4 or at least throw together a reasonable backup/emergency system.
Since Buster no longer allows unzipping I'm kind of desperate to find a working imager for PC. Gzip is doing a good job on the Pi for flashing but I still need to find a good image maker and something for PC.
I might suggest some notes on the page hinting at compatibility.
ConfuSomu
Sat Mar 07, 2020 2:35 am
fruitoftheloom wrote:
Fri Mar 06, 2020 8:39 am
This software does not verify .img has been written correctly.
Wasn't this the reason Etcher was recommended originally, to protect users against fake SD cards, by verifying the written data?
bensimmo wrote: If QT is the culprit ( or a setting in QT) then it needs looking at. Cross platform ease cannot come before disabilities or accessibility.
Agreed. Accessibility, including correct font scaling, is a very important point. It needs to be looked at.
If you are low on RAM, make sure to use zram! ;)
I found & use this zram setup script: https://github.com/novaspirit/rpi_zram
A post about zram: t=207304
Make sure to disable dphys-swapfile and mount the tmp folders in RAM. Also learn about SysRq!
emma1997
Sat Mar 07, 2020 5:15 am
I think h2testw does a good job finding fakes and also gives a rough indication of speed. I don't even bother if it was a $15 card from local chain but definitely if it's a $3 Ebay deal. Super friendly interface and German language (if you are inclined, lol).
Sat Mar 07, 2020 5:31 am
What I use does verification:
viewtopic.php?f=91&t=267080#p1622564
fbe
Sat Mar 07, 2020 12:18 pm
The only difference that does matter here is, that the Debian with Raspbian Desktop download is an image and the Raspbian with Desktop download is a ZIP archive with an image in it. ;)
Sat Mar 07, 2020 12:26 pm
That is so wrong Debian with RDP IS an .ISO:
2020-02-12-rpd-x86-buster.iso
https://downloads.raspberrypi.org/rpd_x ... 020-02-14/
fbe
Sat Mar 07, 2020 12:35 pm
sudo dd if=2020-02-12-rpd-x86-buster.iso of=/dev/sdb
I tried it before writing.
Sat Mar 07, 2020 12:36 pm
Yes. It is.
An ISO is an image file that can be used on a DVD or USB storage (if it is a Hybrid variety).
Unreadable squiggle
gordon77
Sat Mar 07, 2020 1:21 pm
I downloaded the WINDOWS version, installed OK.
When Run it lets me choose a OS OK BUT doesn't see any SD CARDS, even though there is one in a USB adapter, seen by Windows explorer OK.
On my 2nd PC it sees the adaptor but not the SD card so won't write .
Any clues ?
plugwash
Sat Mar 07, 2020 3:27 pm
It is an ISO9660 DVD image, it's also a bootable image for USB sticks and similar.
This is possible because ISO9660 reserves a 32K system area at the start of the drive. That is more than enough space to fit in a MBR boot sector and partition table for legacy PC booting and a GPT partition table for UEFI booting.
BerndGaykema
Sat Mar 07, 2020 3:48 pm
Couldn't imager also be used to write Debian with Raspberry Pi Desktop images to a USB drive?
Same here. I use a RPi 3 with a USB device instead of a SD card.
Now I can't prepare the USB device anymore as Imager doesn't see the USB drive.
When trying to download the latest lite-image (to use BalenaEtcher) I have the problem that I can't find this version...
HELP !
Introducing a new tool is fine, but let the old way of working intact until all child-diseases have been overcome!
FTrevorGowen
Sat Mar 07, 2020 3:53 pm
Any clues ?
I've just re-tested on an old Win8 Acer Aspire V11 Touch this time using a uSDHC card in a USB3 (single) card reader/writer (rather than the built-in SD slot + uSD-to-SD adapter which I'd tested with previously) and, FWIW, it worked fine for me. Your attachments appear to indicate that you were using a multi-card device which, IIRC from another post, can mean that Windows "finds" empty (dummy) drives which could be the cause of your issue. (I'm posting from a P4B booted from the newly written and updated card via a VNC connection from my main P4B)
Trev.
Sat Mar 07, 2020 4:00 pm
HELP !
NoobS and Standalone downloads are still available, nothing has been removed:
https://www.raspberrypi.org/downloads/noobs/
So nothing has changed and not sure what your issue is......
gordon77
Sat Mar 07, 2020 4:26 pm
Any clues ?
Trev.
I'm using a SanDisk SD card adapter that came with a SD card. Works fine with win32diskimager.
FTrevorGowen
Sat Mar 07, 2020 4:47 pm
Any clues ?
Trev.
O.K. That looks like it's a USB2 device. What type of P.C., Windows version, any built-in card slots or other USB "drives" plugged in?
Did you plug the card into the reader before plugging the reader into the P.C. and then running the new tool (that's what I did since I known uSD cards not to be "picked up" if plugged into a "live" reader regardless of O.S.)? TBH I was surprised that the Acer's built-in SD card slot worked since SDHC/XC compatibility is not "guaranteed" on "older" m/c's (unless they're labelled as such - a rare occurrence).
Trev.
gordon77
Sat Mar 07, 2020 4:54 pm
1 is old pentium, 2nd a i5. Both windows 10, pentium 32 bit, i5 64 bit windows. No other usb drives plugged in, no SD slots.
Fixed !! faulty SD to micro SD adaptor !!
DaQue
Sat Mar 07, 2020 10:56 pm
Will this enable installing to 128 Gb micros cards or do you still have to do extra steps if over 32 Gb?
DirkS
Sun Mar 08, 2020 12:31 am
Should work fine, just like balenaEtcher and others.
Only NOOBS installs are affected by it as cards over 32GB are by default formatted to exFat in Windows.
Writing images uses a different mechanism
