MangoLinux804
Wiring Harness
Tue Mar 03, 2020 6:35 pm
Where can I find the proper wiring harness that fit the GPIO pins?
Burngate
Re: Wiring Harness
Tue Mar 03, 2020 6:53 pm
The Google you're looking for is "40-way ribbon cable"
alphanumeric
Re: Wiring Harness
Tue Mar 03, 2020 7:20 pm
Wiring harness to connect to what, exactly?
There is also this option.
https://shop.pimoroni.com/products/mak ... per-jerky
MangoLinux804
Re: Wiring Harness
Wed Mar 04, 2020 4:49 pm
I need to add an RTC ,but my case doesn't have room, so I want to make a little cable to attache the RTC on the outside of the case.
alphanumeric
Re: Wiring Harness
Wed Mar 04, 2020 6:20 pm
The case your using and the RTC you plan on using may help.
