black screen RBP4
Posted: Sat Feb 29, 2020 3:03 pm
by meergranensapje
hi there,
so i install noobs on my raspberry and that looks fine but after the reboot the screen stays black.
i used a micro hdmi to hdmi cable in to a monitor.
Re: black screen RBP4
Posted: Sat Feb 29, 2020 8:23 pm
by Botspot
Try installing NOOBS again.
Or, flash the SD card with Raspbian using Etcher. A good tutorial is here:
https://learn.adafruit.com/adafruit-ras ... ta-slash-7
Posted: Sun Mar 01, 2020 5:34 pm
by peppe8o
Also... are you using a proper Power Supply? Consider that RPI4 should be powered with a 5V - 3A power supply, so if you are using a common Smartphone power supply not able to provide enought amperage your RPI could not boot...
Posted: Sun Mar 01, 2020 5:57 pm
by FTrevorGowen
meergranensapje wrote: ↑Sat Feb 29, 2020 3:03 pm
hi there,
What make/model etc. of monitor? Have you (can you) enable SSH and a network connection by adding the appropriate files to the uSDHC card? What do the (red) PoWeR and (green) ACTivity leds do when you power up the P4B?
Trev.
