How can i connect Raspberry PI 4 with Arduino uno ?
Posted: Thu Feb 27, 2020 12:43 am
by Slim1996
Hello !
I have a project for educational purpose, the project runs a 3 step motors with 3 axes (X,Y,Z)
the motors will be running via Arduino ( i tried to run the motors with the old fashion way with Arduino and it worked perfectly fine ) my problem is how can i run those motors using the Raspberry PI 4, (i did installed Arduino in the RPI 4 and am connecting the Arduino and the RPI 4 via USB cable )
do i have to run a commande or something using python so it can run the Arduino code ? if yes can you enlighten me with it it would much appreciated :)
if not can you propose a solution for me ?
and thank you :D :D
Re: How can i connect Raspberry PI 4 with Arduino uno ?
Posted: Thu Feb 27, 2020 10:21 am
by topguy
After plugging in the Arduino you should normally have a new serial port named "/dev/ttyUSB0" or "/dev/ttyACM0" or maybe "/dev/ttyACM1".
My preferred way to find the exact name is, to let the Pi boot, plug in the Arduino and then look at the last lines from the output of the command "dmesg".
I will show how the kernel detects the new USB device and what name it is assigned.
Then read this:
https://www.instructables.com/id/Connec ... duino-Uno/
..and then come back with further question..
Posted: Thu Feb 27, 2020 10:39 am
by neilgl
If you want to run the stepper motors using the pi4, not the Arduino, there are several python libraries for stepper motors, so you could recreate the sketch (Arduino) functionality in python. Which stepper motors are you using?
Posted: Thu Feb 27, 2020 10:47 am
by PiGraham
Hello !
That sound a bit like a 3D printer or CNC. Typically an Arduino or similar runs a program that interprets g-code (e.g. Marlin) and moves the motors according to g-code instructions. A program on RPi or other computer sens g-code command strings over serial / USB-serial.
Octoprint is a popular program available for RPi to control 3D printers.
So you need software at each end of the serial connection to exchange information in a defined format to instruct how to move the motors.
Posted: Thu Feb 27, 2020 9:18 pm
by Slim1996
Then read this:
that sounds great i will give it a try the next Monday and i will get back to you with some feedback .. appreciated
Posted: Thu Feb 27, 2020 9:24 pm
by Slim1996
I am currently using the nema 17 stepper motor. I want to run the stepper motor via Arduino not RPI so i'am searching how can i use the sketch to work with RPI
Posted: Thu Feb 27, 2020 9:31 pm
by Slim1996
Hello !
Yes that is similar to a 3D printer or CNC. Can you give me some links that can help me to work with it or something because i'am not familiar with G-code (i'am still a newbie to python and RPI :P ) it will be much appreciated and Thank you
