I have been thinking about a project to monitor if the main power to a boat loses power. The boat has a 50a shore power cord - two phase 125v legs.
I have considered a split core power transformer. I have looked at connecting some data feed from the inverter.
I am thinking - what if I used a non-contact voltage detector type circuit.
Something like https://makezine.com/projects/non-conta ... -detector/
Instead of using a battery, I was thinking of using the 3.3v pin on the RPi and ground pin.
I am wondering if I should isolate the Rpi with an optocoupler or just a photo resister on the LED in the detector in the project above.
I am not interested in the voltage or current, just if it is ON / OFF. I will then have the RPi send an SMS text.
Suggestions?
