I have a USB camera that work great for half a year ~
last week I have notice that it stop working
I have remove it and the plug it back(still not working) - this is what I get in the syslog
Feb 21 13:30:52 raspberrypi kernel: [260863.221689] usb 1-1.1.2: new high-speed USB device number 13 using dwc_otg
Feb 21 13:30:52 raspberrypi kernel: [260863.378345] usb 1-1.1.2: New USB device found, idVendor=0ac8, idProduct=3500, bcdDevice=10.07
Feb 21 13:30:52 raspberrypi kernel: [260863.378353] usb 1-1.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Feb 21 13:30:52 raspberrypi kernel: [260863.378358] usb 1-1.1.2: Product: A4 TECH HD PC Camera
Feb 21 13:30:52 raspberrypi kernel: [260863.378362] usb 1-1.1.2: Manufacturer: A4 TECH
Feb 21 13:30:52 raspberrypi kernel: [260863.378366] usb 1-1.1.2: SerialNumber: MI1320_SOC
Feb 21 13:30:52 raspberrypi kernel: [260863.379335] uvcvideo: Found UVC 1.00 device A4 TECH HD PC Camera (0ac8:3500)
Feb 21 13:30:52 raspberrypi kernel: [260863.382258] uvcvideo 1-1.1.2:1.0: Entity type for entity Processing 2 was not initialized!
Feb 21 13:30:52 raspberrypi kernel: [260863.382268] uvcvideo 1-1.1.2:1.0: Entity type for entity Camera 1 was not initialized!
Feb 21 13:30:52 raspberrypi kernel: [260863.382274] uvcvideo 1-1.1.2:1.0: Entity type for entity Extension 4 was not initialized!
Feb 21 13:30:52 raspberrypi kernel: [260863.382458] input: A4 TECH HD PC Camera: A4 TECH H as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.2/1-1.1.2:1.0/input/input5
Feb 21 13:30:57 raspberrypi mtp-probe: checking bus 1, device 13: "/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.2"
Feb 21 13:30:57 raspberrypi mtp-probe: bus: 1, device: 13 was not an MTP device
Feb 21 13:30:57 raspberrypi systemd-udevd[18577]: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
Feb 21 13:30:58 raspberrypi kernel: [260869.341841] Under-voltage detected! (0x00050005)
Feb 21 13:31:04 raspberrypi kernel: [260875.581869] Voltage normalised (0x00000000)
that the camera is broken?
Thanks ,
