freedomjazzdance
RP4b + 7" Monitor + Logitech K380 bluetooth keyboard
Mon Feb 17, 2020 12:25 am
My first post.
1. I just assembled a RP4b onto a 7" monitor board into a plastic shell designed for the monitor. it doesn't fit correctly and forcing it would probably crack the plastic. Is there someone in Sydney who is willing to help me?
2. RP4b recognises the K380 keyboard and the keyboard flashes recognising the RP but the pairing never completes. One or the other dropping out. Logitech's helpdesk is useless as they only know Win and Mac.
Assistance is welcomed.
FJD
freedomjazzdance
Re: RP4b + 7" Monitor + Logitech K380 bluetooth keyboard
Tue Feb 18, 2020 7:23 am
The answer to both questions came by going back to the distributor and (suspecting) discovering that there were incorrect parts supplied. I now have a 3b which works fine (slower) with the 7" monitor and the Logitech keyboard and the email is also easier to configure.
The 4b is now earmarked for a CCTV system.
FJD
alphanumeric
Tue Feb 18, 2020 10:59 am
What case and 7 inch monitor did you get?
I ask because I have a SmartiPi V2 case for my Pi Foundation 7 inch Touch Screen. It's compatible with a Pi 3 or a Pi 4. The older version 1 case will only work with a Pi 3.
freedomjazzdance
Tue Feb 18, 2020 10:59 pm
How do I tell the difference?
alphanumeric
Wed Feb 19, 2020 11:51 am
freedomjazzdance
Wed Feb 19, 2020 10:00 pm
Neither looks like what I have!
There is no bottom plastic stand and plug holes are in different places.
alphanumeric
Wed Feb 19, 2020 10:06 pm
Ok, its not a Smartipi case. There are other similar cases out there. Yours was made for a Pi 3. The Pi 4 has the USB and ethernet swapped around, it won't fit in a lot of the Pi 3 cases. The HDMI and USB cutouts will be different too. You could likely modify it to fit a Pi 4. You'd have to do some cutting drilling though.
freedomjazzdance
Wed Feb 19, 2020 10:14 pm
As I suspected.
Not a big deal. I purchased a 3b and it fits and works just fine. I have earmarked the 4b for a CCTV system. I HAVE TOO MANY COMPUTERS!!!
While I've got your attention, any idea how to get the on-screen keyboard working?
alphanumeric
Thu Feb 20, 2020 10:59 am
You have to install one. I do believe its
sudo apt install matchbox-keyboard
Then launch it from the start menu. There are likely other ways to launch it once its installed, I don't know what they are though.
freedomjazzdance
Fri Feb 21, 2020 12:30 am
If I need to download/install it, I'll stay with my bluetooth keyboard which I find preferable.
