david_1234
how to control volume output when using external sound card?
Mon Feb 10, 2020 10:39 am
Hello ,
I'm using a USB sound card on my pi
wanted to know how can I chagne the output volume of it ?
I haver try to use this command
amixer set PCM -- 85%
but it doesn't change the volume
in order to play file I use this command in python
TestSound = "/home/pi/Documents/test.mp3"
os.system("mpg123 -o alsa:hw:1,0 " + TestSound)
what do I need to add in order to change the volume?
Thanks ,
david_1234
Re: how to control volume output when using external sound card?
Mon Feb 10, 2020 10:45 am
found it
 mpg123 -o alsa:hw:1,0 -f -2000 /home/pi/Documents/test.mp3
the maximum value of the amplitude is 100% which coressponds to 32768
got it from here
https://unix.stackexchange.com/question ... -of-mpg123
maybe it will help anyone alse also....
