CPC RPI-B-KIT2 - No Worky
Posted: Fri Dec 21, 2012 9:50 pm
Hi All,
Second RPI-B-KIT2 from CPC - not working. I've managed to avoid the PSU supplied as it does not power the Pi. I routed the power lead into the supplied USB hub and it powered up fine. After boot, the mouse dows not glow and the keyboard has no effect on the system.
This is the second RPI-B-KIT2 system I've had and the second one that will not respond to the keyboard. At least the mouse glowed in the first one. Now I boot and get stuck in "Raspi-config" as the keyboard cannot change any of the options or even proceed with defaults. At least the first one sometimes would respond to keys for 2-3 presses after about 3-4 seconds each key.
However, the first one was no more use than this one. Is it something I'm doing? Is the RPI-B-KIT2 a piece of rubbish? Where do you guys with working Pis get your stuff?
