HDMI to VGA cable
Posted: Fri Dec 21, 2012 2:18 pm
by superdexter
Hello everyone,
I am a new Raspberry Pi user and i hope you can help me with a problem.
I am trying to use my Pi with a flat sceen PC monitor which only has an SVGA input, and so i have connected the Pi with an HDMI to VGA cable. However the monitor does not seem to be getting a signal (but the Pi works fine HDMI to HDMI on a TV).
I hope someone can help.
Thanks, Michael .
Re: HDMI to VGA cable
Posted: Fri Dec 21, 2012 5:39 pm
by ski522
You can't use just a cable that converts just the connector type to VGA. HDMI is a digital signal, while VGA is an analog signal, so you need a converter that will convert the digital HDMI signal into an analog VGA signal. Something like this would do the job http://www.meritline.com/hdmi-male-to-v ... 86032.aspx
